The client is experiencing a decrease in page speed after installing WPML on their website.
We recommend the following steps to improve your site's performance:
1. Disable "Adjust IDs for multilingual functionality" under WPML -> Languages -> Make themes work multilingual, especially if you are using well-known themes like Astra.
2. Reduce the overall page size by compressing media files using plugins like EWWW.
3. Install and configure a page caching plugin such as Super Cache, W3 Total Cache, or WP-Rocket.
4. Implement object caching with Redis to enhance backend performance. This requires support from your hosting or VPS and can be set up using the Redis Cache plugin. Note that some caching plugins like W3 Total Cache also provide object caching.
5. Ensure that the Query Monitor plugin is only active during testing phases to identify slow queries and not enabled in production as it can degrade performance.
If these steps do not resolve the issue or if the solution seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should the problem persist, please open a new support ticket.
This topic contains 7 replies, has 3 voices.
Last updated by Sergo NADJARYAN 1 year, 4 months ago.
Assisted by: Mateus Getulio.
August 22, 2024 at 6:19 am #16092734
Sergo NADJARYAN
I am trying to optimize page speed for my site after installing WPML. Here is the link to the page where the issue can be seen: hidden link
After installing WPML, my site’s page speed has significantly decreased.
Could you please help me configure my WPML settings to increase the speed?
August 23, 2024 at 8:56 am #16097766
Dražen
Thanks for contacting us.
Can you please install the Query monitor plugin and share with us the results with the WPML plugin and when the plugin is disabled?
- https://wordpress.org/plugins/query-monitor/
Drazen
August 26, 2024 at 6:51 am #16102657
Sergo NADJARYAN
Hello Draze, Thank you for support but site owner dont want to install additional plugin on site, I'm sorry. Please help me to find another way.
August 26, 2024 at 9:10 pm #16106804
Mateus Getulio
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
August 29, 2024 at 8:13 pm #16121929
Mateus Getulio
Hello there,
I started debugging this issue but I'd like to ask permission to make another copy/staging version of your site where I can debug this locally.
I'll make sure to delete this copy as soon as we get this issue fixed.
It is important to test a different setup as part of the troubleshooting.
Thank you, please let us know.
Mateus
August 30, 2024 at 8:23 am #16123601
Sergo NADJARYAN
Thank you for support. Ok. No problem. You can copy this installation. Waiting for your answer 🙂
August 30, 2024 at 7:27 pm #16126204
Mateus Getulio
All right,
I ran some tests and have some findings to share.
Firstly, checking the difference in the performance when WPML and its addons are not enabled gave me such results:
• Without WPML and its addons
Home page total load time: 3.5 seconds
Memory usage: 121.0 MB
DB queries run time: 0.2144s
• With WPML and its addons
Home page total load time: 4.5 seconds
Memory usage: 149.8 MB
DB queries run time: 0.2843s
Even when WPML is disabled, I'm experiencing some performance issues, and by enabling WPML, the load time and queries number increase slightly, but in a way that is under the acceptable and expected of WPML.
I was able to get the total load time to stay bellow the 4s window(pretty close to when WPML is not on) by going to WPML -> Languages -> Make themes work multilingual and disabling "Adjust IDs for multilingual functionality". For known themes like Astra, this functionality can be disabled without causing issues to your site.
Here are some recommendations that might help increase the performance of the site in general:
- Lower the weight of the page size in MB. Please consider using compress media solutions (EWWW or similar), minimize the media quantity through the pages.
- Consider using the plugin Index WP MySQL For Speed
- Try to use page caching plugin like Super Cache, W3 Total Cache, or WP-Rocket.
- Try to implement object caching with Redis. This significantly improves performance on backend. It requires support on hosting or VPS and a plugin like this one: https://wordpress.org/plugins/redis-cache/. Some page caching plugins like a W3 Total Cache can provide object caching too. In this case, Redis Cache plugin is not needed.
- Make sure that Query Monitor is not enabled for production and only enabled during testing times to determine slow queries (the plugin usually overloads and creates more performance issues).
Thank you,
Mateus
August 31, 2024 at 6:21 pm #16128035
Sergo NADJARYAN
Very detailed answer. Thank you. I will try everything as soon as possible. Thank you again. Now we can close this ticket.
