Supporter timezone: Europe/Vienna (GMT+01:00)
This topic contains 23 replies, has 0 voices.
Last updated by Lucas Vidal de Andrade 2 months, 3 weeks ago.
October 15, 2025 at 8:54 am
thanakritK
I am trying to enable the WPML plugin on my WordPress site, specifically for pagination in Elementor post and loop grid. The issue can be seen on this page: hidden link.
When I enable the WPML plugin, the pagination shows the wrong URL. I expected to see the URL as hidden link, but instead, I got hidden link.
Why does enabling WPML change the pagination URL?
How can I fix the pagination URL to display correctly with WPML enabled?
October 15, 2025 at 11:55 am #17486919
WPML Supporter since 11/2023
Hey there,
After investigating, I suspect this a broader compatibility issue between WPML and Avada. To confirm this, I've created a Sandbox (testing website), so we can check how the pagination behaves on a controlled server, from 0.
Please install Avada, and create blog posts so we have pagination on the blog archive page. Please don't take any other steps. I'll install and setup WPML on this website, and check how it behaves myself. You can access the website here:
The idea here is to check the pagination feature in isolation, so please don't import or create any unnecessary and unrelated content. I know this takes some effort, so I appreciate your cooperation on this matter.
October 20, 2025 at 4:11 am #17497449
thanakritK
Hello, Are you checking? .I'm still waiting for a solution.
Thank you
October 20, 2025 at 6:53 am #17497640
It seems you've missed my last messages. Please follow the instructions I sent and let me know when you're ready! This way, I can continue checking the issue.
October 21, 2025 at 1:20 am #17501212
thanakritK
i don't use avada , i use astra theme, and elementor plugin
October 23, 2025 at 1:12 am #17510372
thanakritK
Not sure, you are misunderstanding. i don't use avada , i use astra theme, and elementor plugin. In this case I used the Elementor widget to create the post grid and pagination
October 23, 2025 at 12:54 pm #17512547
Yes, precisely. I understood that. I need to check how your setup behaves on our testing website. Can you please just follow my instructions and let me know? Create the pagination using Elementor, while Astra is the theme. Let me know. Sorry if my instructions are unclear. What I need you to do is to recreate an example of the issue, from scratch, on the testing website I've created.
October 29, 2025 at 7:56 am #17528039
thanakritK
this same problem
October 29, 2025 at 2:23 pm #17529845
Thank you for sharing and for cooperating 🙂 I'll escalate it to analysis, which usually takes a few days. I'll keep you informed.
October 30, 2025 at 10:47 am #17532169
Hey there,
I lost the access to the Sandbox. I shared previously:
"The idea here is to check the pagination feature in isolation, so please don't import or create any unnecessary and unrelated content."
Though I see the site has many pages, images etc. Have you imported a whole website to the sandbox? I'm confused. It seems you overwrote what we had. Let me share a new Sandbox:
Please follow ONLY the steps below. Please DO NOT install, create or import ANYTHING that's not related to the issue:
1. Install Astra
2. Install Elementor
3. Recreate the pagination issue
Please DO NOT import, create or install ANYTHING that's not related to the issue. I need to check the issue in isolation, with no external interferences, so I can escalate that to our devs.
November 3, 2025 at 1:12 am #17539352
thanakritK
i do finish hidden link
November 3, 2025 at 12:30 pm #17541037
Hello there,
Thank you so much for sharing. There's some mismatch, though. I created a Sandbox myself, setup WPML, installed Astra, Elementor, created a few posts and created a page with the Elementor Posts widget, exactly as you did. I didn't have any issues, the pagination is working flawlessly, please check:
Can you please share in detail, the steps you took? There must've been something different, as it's working for me. Please be as concrete and as descriptive as possible, that might help us find the cause of the problem.
November 6, 2025 at 1:14 am #17551963
thanakritK
1. Install Astra Theme
2. Install Astra child Theme and Activate
3. Install plugin Astra Pro
4. Install plugin Elementor and Elementor Pro
5. Active plugin WPML Multilingual CMS and setup
6. Create post
7. Install plugin Duplicate Page
8. duplicate post 12 post
9. Create page with Elementor Posts widget
November 6, 2025 at 4:39 pm #17554882
Hey there, I'm double-checking all the data and the steps and will get back to you. Thank you for your patience.
November 7, 2025 at 11:10 am #17556795
Hey there,
Thank you for waiting. Please follow these steps on your website or on its staging version:
1. Activate the parent Astra theme;
2. Create a new page with pagination from scratch;
3. Check the results and let me know;
Also, I need access to the staging website. I tried accessing it, but it seems to be offline. Can you please restore it?
If you need to share access again, I've activated the private fields. The required fields can be found below the comments section. The information you enter is private, i.e. only you and I can see it and have access to it.
I may need to replicate your website locally. To do this, I need to temporarily install a plugin called "Duplicator" or "All in One WP Migration" on your website. This will allow me to create a copy of your website and content. Once the issue is resolved, I will delete the local website. Let me know if this works for you.
IMPORTANT
Please make a backup copy of the site files and database before giving us access.
- If you do not see the wp-admin/FTP fields, this means your post and site login details are being made PUBLIC. DO NOT post your website details if you do not see the required wp-admin/FTP fields. If you do not, ask me to enable the private box. The private box looks like this:
The topic ‘[Closed] pagination in post (elementor post and loop grid ) show wrong url’ is closed to new replies.
