- 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 12:00 – 15:00 -
This topic contains 23 replies, has 0 voices.
Last updated by Lucas Vidal de Andrade 5 months, 2 weeks ago.
November 10, 2025 at 2:04 am #17560505
thanakritK
i do finish and reply you finish hidden link
November 11, 2025 at 8:27 am #17565120
WPML Supporter since 11/2023
Ok,
I sincerely apologize for how long this is taking, but there's something stopping me from moving forward: you are able to reproduce the issue from scratch, while I'm not.
Please check the steps I followed here:
I have NO issues, everything is working 100% correctly. There MUST BE something different, between what you are doing and what I'm doing. Please clarify what that is. How are you able to reproduce the issue? Please explain as best as you can, preferably recording a video while you do it. You can use Loom for that: hidden link
I'll wait for your feedback.
November 12, 2025 at 7:35 am #17568918
thanakritK
Where do you want me to repeat the problem?
November 12, 2025 at 7:39 am #17568921
thanakritK
i do in hidden link
November 12, 2025 at 3:24 pm #17571675
Thank you for sharing. Again, I'm sorry it's taking longer than usual to find a cause for this. I've decided to escalate your issue to our development team, to see if they have any insights on what might be going on.
To do that, I need a copy of your website. Nonetheless, I noticed that your server blocks both tools we use to migrate sites and create copies. In this case, I need access to a staging version where we can make tests that might break the website. If you have one, please send me the link here. You can keep the same user you already shared there, so you don't need to share access again. Thank you for your patience and cooperation.
November 18, 2025 at 6:13 am #17586410
thanakritK
you can use hidden link and user pass same message on (November 10, 2025 at 2:03 am)
November 18, 2025 at 11:37 am #17587788
Thank you for sharing. The issue is escalated. I'll keep you updated.
November 19, 2025 at 9:17 am #17590797
Hello there,
The issue seems to be indeed a broader compatibility issue between Elementor and WPML, and not exclusive to your website. We are looking for a permanent solution, and can offer a workaround in the meantime:
Go to WPML > Settings > Post Types Translation and select "Translatable - only show translated items" for posts and pages. They will need to be translated to show up;
I'll keep you informed.
November 27, 2025 at 11:10 am #17614641
Hello there,
We found this to be a compatibility issue between Elementor and WPML. We are in touch with them to find a permanent solution, but I don't have a deadline on that. Meanwhile, it's necessary to use the workaround I shared. You can find more information here:
https://wpml.org/errata/elementor-pro-posts-widget-pagination-issues/
Please let me know if the solution works for you.
The topic ‘[Closed] pagination in post (elementor post and loop grid ) show wrong url’ is closed to new replies.
