Last updated by Osama Mersal 1 year, 10 months ago.
Assisted by: Osama Mersal.
September 9, 2023 at 3:47 pm #14369823
reneD-25
I am trying to:
I'm trying to figure out how to fix this problem that appears on the homepage on my site with updated avada theme (Warning: Invalid argument supplied for foreach() in /home/customer/www/beb-vincent.it/public_html/wp-content/plugins/fusion-builder/inc/class-fusion-dynamic-data.php on line 333)
I expected to see:
I simply would not like to see the error
Instead, I got:
Screenshot 2023-09-09 at 17-45-32 B&B Vincent Scalea - B&B VINCENT SCALEA.png
September 10, 2023 at 9:19 am #14370735
Osama Mersal
WPML Supporter since 02/2020
Please edit your wp-config.php file and add the following lines below the debug line.
// Disable display of errors and warnings, which is recommended on a live site.
define('WP_DEBUG_DISPLAY', false);
@ini_set('display_errors',0);
After that, please save the file and check if the errors disappeared from the front end.
If you are unfamiliar with editing the wp-config file, please get in touch with your host provider to make the change.
Osama
The topic ‘[Closed] php problem with avada theme’ is closed to new replies.
