Last updated by Osama Mersal 1 year, 10 months ago.
Assisted by: Osama Mersal.
September 28, 2023 at 2:43 pm #14482775
giovannaB-3
I am trying to:
Translate Elemento Loop Item containing posts
Instead, I got:
The page is translated, but loop item does not even apepars in the page (see screenshot)
Thank you for supporting me
October 1, 2023 at 9:11 am #14492615
Osama Mersal
WPML Supporter since 02/2020
1) First of all, sorry for the late reply due to a higher workload. Please let me know if this loop template is translated.
Also, please edit the translated page using Elementor to check if the translated loop template is selected correctly.
2) It's unrelated to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/)
You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line:
/* Memory Limit */
define( 'WP_MAX_MEMORY_LIMIT', '256M');
Osama
The topic ‘[Closed] Post contents (Title, resume, description) used inside loop item in Elementor’ is closed to new replies.
