You are trying to translate posts using WPML, but the posts are not translating as expected. Instead of seeing the translated version, the page didn't translate.
We recommend updating to the latest version of WPML, specifically version 4.8.4, which includes recent bug fixes and improvements that may resolve your issue. You can find the latest version under My Account → Downloads on our website. If the update isn't visible, click the 'Check for updates' button under Plugins → Add New Plugin → Commercial. If the problem persists after updating, please consider opening a new support ticket.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue continues, do not hesitate to open a new support ticket for further assistance.
Last updated by Andrey 5 months ago.
Assisted by: Andrey.
October 7, 2025 at 12:59 pm #17463881
tobiO
I am trying to translate posts using WPML. Please see the video below for more details: hidden link. The issue can also be seen on this page: hidden link.
The posts are not translating as expected. Instead of seeing the translated version, the page didn't translate.
Why are my posts not translating?
How can I fix the issue where the page doesn't translate?
October 7, 2025 at 3:11 pm #17464332
Andrey
WPML Supporter since 06/2013
Could you please share a screenshot of what you see under WPML → Advanced Translation Editor → Error Logs?
I have enabled debug information for this support ticket. Please follow this link for instructions on how to retrieve this information from your site and send it to us: http://wpml.org/faq/provide-debug-information-faster-support/
October 10, 2025 at 12:38 am #17473168
tobiO
This is what the last error logs says
2025/10/10 12:31:01 AM
AMS Server Communication
Api error missing resource: No sitekey found for this website
0
0
{"errorData":{"status":400,"title":"Api error missing resource","detail":"No sitekey found for this website"}}
October 12, 2025 at 1:00 pm #17477327
Andrey
Thank you for your feedback.
Can you try the following steps?
1. Go to Plugins → Add New and click the Commercial tab. Click Unregister WPML from this site.
2. Once the page loads, click on Register WPML. A message asking you to enter the site key will appear. Click on Get a key for this site.
3. In your WPML account, complete the site key wizard and set it to Production site.
4. Copy your new key and paste it in the Commercial tab. When done, you can delete your old site key in the WPML account.
If it doesn't allow you to create a new site key, remove the old first.
Check if the issue still exists.
October 14, 2025 at 6:18 am #17481916
tobiO
Our set up is a subsite so I had to go to the network admin to add a new plugin; however, I couldn't find the commercial tab on the add new plugin page.
I went back to the subsite plugin page lv.uwc.org, clicked the registered button under wpml on the plugin page which took me to the installer page. I clicked unregister wpml from this site but nothing happened, it reloaded and the button still said unregister.
I went to the main uwc.org site and clicked the registered button under wpml on the plugin page and it also took me to the installer page. I clicked unregister wpml from this site and this time it unregistered.
I deleted the uwc.org key from my account and created a new one, added it on the site but the translation still didn't work.
The same thing that happened in the previous video is still happening.
October 14, 2025 at 12:09 pm #17483702
Andrey
Please ensure WPML plugins are updated to the latest version, WPML 4.8.2.
October 20, 2025 at 7:46 am #17497891
Andrey
Thank you for providing access.
It looks like I don’t have access to the staging site you mentioned — hidden link. I was able to log in to the main site (hidden link), but it doesn’t appear to include the staging site within the same network. Could you please confirm what I might be missing?
We’ve just released a new version — WPML 4.8.3. Could you please update WPML and test the issue afterward? We’ve had similar cases that were resolved with this update.
You can check the latest releases under My Account → Downloads on our website.
Instructions for updating WPML can be found here:
http://wpml.org/faq/install-wpml/
If you don’t see the update right away, click the Check for updates button under Plugins → Add New Plugin → Commercial.
October 24, 2025 at 2:47 am #17514364
tobiO
We updated to 4.8.3 and it is still not working.
Please try again, you should be able to log in now. The password is the same as the original one sent.
October 24, 2025 at 7:54 am #17515125
Andrey
Before I proceed with further checks, could you please test this using the latest version — 4.8.4 — which includes the most recent bug fixes and improvements?
In my previous message, I mistakenly referred to version 4.8.3, but I meant 4.8.4. Several similar issues were resolved in this latest release.
You can check the latest released versions under My Account → Downloads on our website.
Please let me know if the issue persists after updating.
