The client was unable to see the translated versions of their menus in French and Spanish on the desktop view of their website, although the mobile view and footer menus were displaying correctly.
We recommended the following steps to resolve the issue:
1. Navigate to Appearance -> Menus, select the menu, and copy its ID.
2. Go to WPML -> String Translation.
3. Scroll down and click on the "Translate texts in admin screens »" link.
4. Search for the menu ID.
5. Select the strings you want to translate.
6. Click on the "Add to String Translation" button.
7. Then click on the "« Return to String Translation" link.
8. Translate the menu ID.
For more detailed instructions, please refer to our guide on translating texts in the admin texts screen.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the issue persists, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
Last updated by Osama Mersal 1 year, 3 months ago.
Assisted by: Osama Mersal.
March 3, 2024 at 12:35 am #15366236
jimG-9
I am trying to: Create French & Spanish menus. They worked for a while but then stopped.
The site is still in development.
I expected to see: menus in the correct language
Instead, I got: Just the original language menu in the desktop view. Strangely, in mobile view, the menus are in the correct language and work properly. Also the Footer menus work properly in both desktop and mobile view.
Other information:
• Running on WordPress.com with 512M PHP and WP memory limits
• Website still in development
• All plugins up to date
• Theme plugin – Astra Pro with Spectra
• Other plugins – WPForms, Business Directory, Remove Dashboard Access
• Have attempted numerous ways to solve but nothing works, for example:
o Removed all primary menus and recreated them manually and by sync
o Renamed menus
o Created staging site and removed all plugins except for WordPress.com provided and Astra Pro, Spectra, WPForms, WPML
o Cleared browser cache
o Cleared WordPress cache
o Ran WPML troubleshooting
o Performed string translation
o Removed custom link menu item
• Footer menus work OK
March 3, 2024 at 7:20 am #15366345
Osama Mersal
WPML Supporter since 02/2020
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
March 3, 2024 at 3:11 pm #15366839
Osama Mersal
Thanks for the access details. I checked the issue and was able to translate it by translating the menu ID via WPML-> String Translation. (hidden link)
In order to get the menu ID translatable, please check the following steps:
1- Go to Appearance-> Menus-> Select the menu, and copy its ID
2- Go to WPML-> String Translation
3- Scroll down and click on the "Translate texts in admin screens »" link
4- Search for the menu ID
5- Select the strings
6- Click on the "Add to String Translation" button
7- Then click on the "« Return to String Translation" link
8- Translate the menu ID
Kindly check our guide to know more about translating texts in the admin texts screen. (https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/)
Osama
March 3, 2024 at 6:45 pm #15367187
jimG-9
