The client is experiencing issues with the appearance of WPML language flags in the menu, which do not look aesthetically pleasing due to the menu titles.
We recommend adding custom CSS to improve the appearance of the language flags. Here are the steps to follow:
1. Navigate to your site's backend.
2. Go to Appearance > Customizer > Additional CSS area.
3. Add the following CSS code:
.wpml-ls-item .sub-nav {<br />width: 60px !important;<br />}
4. Save the changes.
This should adjust the width of the dropdown menu to look better. However, if you're looking to have the flags under a world icon with a transparent background, this would require custom coding. Custom work is beyond our support policy, so you may need to hire a developer or consider reaching out to a WPML contractor.
If this solution doesn't look relevant to your issue, please open a new support ticket with us.
Last updated by Mihai Apetrei 1 year, 5 months ago.
Assisted by: Mihai Apetrei.
December 22, 2023 at 11:14 pm #15121875
fatihA-10
My website address is drmertakbas.com.tr
When adding wpml language flags, it looks very bad due to the menu titles. The site I added also uses wpml. How can I fix flag menu like
Other site address: hidden link
If you need to review the site login information
**Hidden**
December 23, 2023 at 6:31 pm #15122855
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
Please go into your site's backend > Appearance > Customizer > Additional CSS area > add the following CSS code and save:
Now, the dropdown menu should look like in the screenshot I attached below (you will see two screenshots: one with the current state, and the other one with the CSS code applied).
Have lovely holidays!
Mihai Apetrei
December 24, 2023 at 1:46 pm #15124309
fatihA-10
Thanks for the reply. Is it possible to show this under a world icon and make the background transparent?
December 26, 2023 at 8:49 am #15128657
Mihai Apetrei
Hi there.
This kind of design will require custom coding and custom work falls out of the purpose of our Support Policy.
You will need to hire a developer or a WPML contactor (https://wpml.org/contractors/) if you need that exact design.
