This topic contains 27 replies, has 2 voices.
Last updated by Kor 1 year, 2 months ago.
August 20, 2024 at 3:37 pm
alexandrosK-5
I have a major problem with 404 pages after updating the VikWP plugin from version 1.4.0 to 1.4.2 on my site hidden link. The issue occurs in both English and Greek. I have restored a backup and contacted VIK plugin support. They mentioned that the issue is related to the file structure of the plugin, which manipulates PHP variables inside the navigation. They suggested ensuring that the links and permalinks have their proper directory for the specific language, such as 'www.yourwebsite.com/en/your-car/'.
404 pages appear after updating the VikWP plugin from version 1.4.0 to 1.4.2.
What can I do to resolve the 404 pages issue after updating the VikWP plugin?
How can I ensure that the links and permalinks have their proper directory for the specific language?
August 20, 2024 at 3:58 pm #16087743
WPML Supporter since 08/2022
Thanks for your patience.
Here is the ticket and please let me know how it goes.
August 27, 2024 at 10:28 am #16108960
alexandrosK-5
They replay that:
Vik Rent Car - Problem after update
Cesare - Staff replied:
Hello Alexandros,
WPML is a plugin that the majority of our clients use, for this reason, we know that our plugin is fully compatible with it. As said in the previous message, please, try to change the permalinks structure, so that the website will find the pages under the language folder.
This means to have the permalinks structure should be (depending on the language) "www.yourwebsite.com/en/your-car/". It should be possible to change the structure directly within the WPML configuration page.
We remain at your disposal should you have more questions.
Kind regards,
Cesare
August 27, 2024 at 12:03 pm #16109587
Thanks for your reply.
As I've mentioned, this is a compatibility issue and you'll need to contact the plugin author and ask them to join our Go global program here https://wpml.org/documentation/support/go-global-program/ so that we can check and make the new version of Vik Rent Plugin compatible with WPML.
A method to speed this up would be to install the required plugins on our sandbox site here hidden link and try to replicate the issue over there.
Once this is replicated, I will create a report and escalate this further to our 2nd Tier Support where they can look into this for us.
August 27, 2024 at 2:35 pm #16110619
alexandrosK-5
Dear Kor,
1. I am unable to compel the plugin creator to join your Go Global program. I have mentioned it to them three times, but it seems they are not interested.
2. A sandbox site won't be helpful, as the issue occurs after the update on the live site.
3. Please escalate this to 2nd Tier Support.
August 27, 2024 at 2:46 pm #16110646
Sorry to hear that the plugin author is not interested in making the plugin compatible with WPML. As mentioned earlier, we need to be able to replicate it on our sandbox site here hidden link before I could escalate this.
Could you share the older version of the Vik Rent Car plugin(Google Drive) so that I can upload it to the sandbox site? Then, I will try to create some examples and hopefully, I could replicate this.
Also, are you using the free version https://wordpress.org/plugins/vikrentcar/ or the paid version? hidden link
August 27, 2024 at 2:50 pm #16110694
alexandrosK-5
I dont have the older version in zip!
You have the codes of the site, can you tranfer the site to sandbox?
I use the paid vesrion
and
August 28, 2024 at 6:59 pm #16116800
Thanks for your patience. I've tried to replicate the issue here hidden link but it works fine.
Could you check and see if I've left out any steps to replicate the issue?
Login Link : hidden link
August 29, 2024 at 6:34 am #16117614
alexandrosK-5
Thanks, so what can I do on the site since it's not working? I think it might be a URL problem, like the Vik plugin support mentioned.
August 29, 2024 at 8:14 am #16118323
Can you make the changes to the URL slug? I'm not sure what you did to the URL on your end.
August 29, 2024 at 8:38 am #16118472
alexandrosK-5
This is the problem for the beginning. Please escalate this to 2nd Tier Support.
September 1, 2024 at 7:31 pm #16129495
Thank you for your patience.
I regret any inconvenience caused, but to proceed with troubleshooting, I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
September 2, 2024 at 4:40 am #16129872
alexandrosK-5
Hello! You have my premision, so please create one by yourself. Thanks.
September 3, 2024 at 4:29 pm #16136902
I'm able to download a copy of the site and I will check and escalate this to our 2nd Tier Support. I will come back to you once I've feedback.
September 5, 2024 at 9:26 pm #16146892
Just letting you know that we're still checking on this and we'll come back to you as quickly as possible.
The topic ‘[Closed] Problem after vikwp plugin update’ is closed to new replies.
