You have a custom taxonomy called 'fitment' assigned to WooCommerce products, set as Not Translatable in WPML. Terms are created in Polish and work correctly in Polish products, but in the English product edit screen, the taxonomy is visible without any terms to select. You want the same taxonomy terms to be shared across all languages without needing translations.
The issue might be related to the
meta_box_cb => 'post_categories_meta_box'
in your custom code. This meta box forces WordPress to render the classic Categories-style checklist metabox for this taxonomy, which relies on wp_terms_checklist() → get_terms(), and WPML filters get_terms() in wp-admin to the current admin language. If your Fitment terms are created only in the default language and don’t have term translations, the checklist in the secondary language can appear empty. To resolve this:
1. Remove the
from your custom code to test if the terms show in the translation without it.
2. Register the taxonomy on init with priority 0 to avoid issues with it being registered too late.
If these steps do not resolve the issue, or if the solution becomes outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Lauren 3 months, 1 week ago.
Assisted by: Lauren.
December 19, 2025 at 5:52 pm #17678824
mariuszG-8
I have a custom taxonomy called “fitment” assigned to WooCommerce products.
The taxonomy is set in WPML as Not Translatable
Terms were created in the default language (Polish)
In Polish (PL) products the taxonomy works correctly and terms are visible
In English (EN) product edit screen the taxonomy is visible, but no terms appear to select
So the terms seem to be language-dependent, even though the taxonomy is configured as shared
What I would like to achieve:
The same taxonomy terms should be shared across all languages
Terms should be visible in both PL and EN (without needing translations)
When I assign a taxonomy term to the Polish product, it should also be available on the English translation
I already tried:
Setting taxonomy to Not translatable
Running WPML → Support → Troubleshooting:
Set language information
Fix terms language
Synchronize posts taxonomies
But the taxonomy terms are still only visible in PL, not EN.
December 19, 2025 at 7:01 pm #17679064
Lauren
It could have something to do with the "meta_box_cb => 'post_categories_meta_box'" in your custom code. Can you remove that to test, and then see if the terms show in the translation without that? That meta box forces WordPress to render the classic Categories-style checklist metabox for this taxonomy. That metabox relies on wp_terms_checklist() → get_terms(), and WPML filters get_terms() in wp-admin to the current admin language.
So if your Fitment terms are created only in the default language and don’t have term translations, the checklist in the secondary language can look like “nothing exists,” even though the terms exist in the default language.
One other thing to test is to register taxonomy on init priority 0 to avoid “registered too late” edge cases.
Please test these and let me know if this changes anything.
