You are trying to display full property details in Arabic and Spanish on your website. The information is correctly translated but does not appear in these languages. The English version displays correctly.
The issue was that admin strings that should not have been translated were being translated, specifically the field names. To resolve this, follow these steps:
1. Go to WPML > Settings > Custom XML Config and add the following configuration to ensure all labels are automatically registered for translation and prevent incorrect string registration:
<wpml-config>
  <admin-texts>
    <key name="wpresidence_admin">
      </key><key name="wpestate_custom_fields_list">
        </key><key name="add_field_label">
          <key name="*"></key>
        </key>
  </admin-texts>
</wpml-config>
2. Navigate to WPML > String Translation > Admin Strings, select all [wpresidence_admin][wpestate_custom_fields_list][add_field_name] options, and click "Remove from String Translation".
3. In WPML > String Translation, select all [wpresidence_admin][wpestate_custom_fields_list][add_field_name] options again and click on "Delete selected strings".
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
This topic contains 21 replies, has 0 voices.
Last updated by masterP 1 month, 3 weeks ago.
October 6, 2025 at 9:16 am #17458892
masterP
I am trying to display full property details in Arabic and Spanish on my website. The information is correctly translated but does not appear in these languages. Previously, this issue was only with Arabic, but now it also affects Spanish. The English version displays correctly. You can see the issue on this page: hidden link.
The property details are visible in English but disappear when switching to Arabic or Spanish.
Why are the property details not appearing in Arabic and Spanish?
How can I resolve the issue of missing property details in these languages?
October 6, 2025 at 10:11 am #17459516
WPML Supporter since 08/2022
Thanks for your reply.
I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
October 6, 2025 at 4:38 pm #17461550
Thanks for your reply. I've checked and I cannot find a solution to this. I kindly ask for a snapshot of the site for further troubleshooting. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
October 7, 2025 at 8:42 am #17462645
masterP
Thank you for your reply
Please create a copy by yourself
Thank you
October 8, 2025 at 7:44 am #17465997
Thanks for your patience. I'm able to create a package on your Website and I will check and come back to you as quickly as possible.
October 8, 2025 at 8:32 am #17466204
masterP
Thank you
Take your time
October 9, 2025 at 2:45 pm #17471854
Thanks for your patience. I've prepared a sandbox site here hidden link and installed the required plugins and theme. Could you please replicate the issue over there so that I can escalate this further to our 2nd Tier Support?
October 10, 2025 at 8:53 am #17473826
masterP
Hi Kor
I can't replicate the issue because the property custom field not available in your website copy, and this is the issue
I think we need to put key license to activate the theme and all items and details
Please check the screenshots
October 10, 2025 at 8:59 am #17473890
masterP
The issue is the details in the Property Custom Fields don't appear in any language, except the default language. On our website, English is the default language.
October 10, 2025 at 9:39 am #17474014
Thanks for your reply. Could you temporarily activate the theme in the sandbox site? Once we're able to replicate the issue, you can deregister the license key and I'll escalate this further to our 2nd Tier Support.
October 10, 2025 at 11:32 am #17474303
masterP
Done, you can check now
October 10, 2025 at 11:45 am #17474368
masterP
this section
October 13, 2025 at 8:34 am #17478715
masterP
Hello Kor, how are you?
Any update?
October 13, 2025 at 8:44 am #17478728
Thanks for your reply and I apologize for the delay due to the weekends. I'm able to see the issue on the sandbox site and I will escalate this to our 2nd Tier Support for further investigation. I will come back to you once I've feedback.
October 13, 2025 at 9:01 am #17478806
Thanks for your patience. While preparing the report, I have a quick question. I checked under WPResidence Theme Options > General > Property Custom Fields and can see the custom fields you’ve created.
However, could you explain what steps you took to make it appear in the “display” box, as shown in the attached screenshot?
