Last updated by Christopher Amirian 1 year, 6 months ago.
December 8, 2023 at 10:59 am #15024897
krzysztofK-28
I'm trying to translate text od acceptance field from pafe piotnet plugin.
mirox.pl
I have form created with pafe piotnet plugin. All of the fields were translated and the problem is acceptance field. That field has unique ID. I've already found that ID WPML/Setting?Custom Fields Translation and swithed from don't translate into translate.
The text of acceptance field is not showing up when I translate a page and I've also tried to find the part of the text in WPML/string translation. Icouldn't find anything.
December 10, 2023 at 3:47 pm #15031617
Christopher Amirian
WPML Supporter since 07/2020
I will add the first reply before this ticket is assigned to one of my colleagues.
It might be the fact that the plugin in question is not compatible with WPML as forms have complicated structure and need compatibility code.
For example we have specific plugins fro WP Forms, Ninja Forms and Gravity Forms to make them compatible with WPML.
I suggest that you follow the steps below to see if you can find it in the admin text section of the string translation to not:
https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/
If not, please install the form plugin to the website below and create a sample form for translation and show which item is not translated, we will report this to the compatibility team. there is no guarantee to have a fix because of the fact I mentioned above, but it worths the try.
The topic ‘[Closed] Problem translating PAFE Piotnet Acceptance field’ is closed to new replies.
