The customer encountered a problem after importing products with translations. The attributes were imported for the primary language, but were not specified for the other translations/languages. Attributes were not displayed in product translations until the product (translation) was saved manually. Additionally, there was no option to switch between languages on the attribute editing page.
1. Attributes are not translatable by default. To translate them, you must go to "WooCommerce > WooCommerce Multilingual > Attributes".
2. Attribute terms are translatable.
In the secondary language import file, you must use the untranslated attribute name. For attribute terms, you must use the translated name in your import file.
If you imported the secondary language without attributes, you will need to manually save your translations so that WPML can sync the products and their variations.
You must first translate your attributes, either manually in "WooCommerce > WooCommerce Multilingual > Attributes" or by following this documentation: https://wpml.org/documentation/related-projects/wpml-all-import-plugin-website-import-with-wpml/importing-multiple-languages-with-wp-all-import-and-wpml/#option-2-import-the-multilingual-terms-using-wp-all-import
Then you can import your products in the secondary language by following that documentation: https://wpml.org/documentation/related-projects/wpml-all-import-plugin-website-import-with-wpml/importing-variable-products-in-multiple-languages-with-wp-all-import-and-wpml/#first-time-import-of-variable-products-in-multiple-languages
Remember that the column must have the name of the untranslated attribute, but for each variation you must use the name of the translated term.
If the solution provided is not relevant to your case, because it may be outdated or not applicable to your situation, we suggest opening a new support ticket. We strongly recommend that you review known issues at https://wpml.org/known-issues/, check the version of the permanent solution and confirm that you have installed the latest versions of themes and plugins. If you need more help, do not hesitate to contact us in our support forum: https://wpml.org/forums/forum/english-support/.
Last updated by 1 year, 7 months ago.
Assisted by: Nicolas V..
