Last updated by Kor 10 months, 1 week ago.
April 7, 2025 at 1:13 pm #16904617
kristoferJ-2
I am trying to resolve an issue with my website hidden link. Previously, I contacted support about a problem with page indexing and an issue with removing the Estonian language. When WPML support removed the language, the entire website broke, resulting in missing images, codes, and texts. We discovered that WPML thinks the site's default language is Estonian, but it should be English. This might be because we copied the Estonian site and then started translating other languages.
Zero images are indexed in Google. When we try to delete the Estonian language, all images, texts, and some codes disappear.
How can we safely remove the Estonian language and turn the whole site to the English version?
What could be causing the image no-indexing issue?
April 9, 2025 at 7:33 am #16911677
Thanks for contacting us. I'm Kor and I was the support agent who assisted you last month. I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
April 9, 2025 at 10:14 am #16912511
Thanks for your reply. I'm getting "ERROR: The username or password you entered is incorrect." when I try to login with the credentials that you shared. Could you check?
April 9, 2025 at 11:39 am #16912999
kristoferJ-2
Ok, sorry, I updated the password, now its correct.
April 9, 2025 at 4:37 pm #16915064
Thanks for your reply. I've removed a portion of the Estonian language content, and the site is still running fine. You mentioned that "the entire website broke, resulting in missing images, codes, and texts". Could you show me where I can see the issue?
April 9, 2025 at 5:43 pm #16915302
kristoferJ-2
Hello.
Check it again. All images are missing now.
Kristofer
April 9, 2025 at 5:47 pm #16915464
Thanks for your reply. I think I know what's going on now. Could you please restore the site from your backup and let me know? I will troubleshoot this further.
April 9, 2025 at 5:57 pm #16915512
kristoferJ-2
Thanks! I made backup.
Kristofer
April 10, 2025 at 9:29 am #16917528
Thanks for your reply. Please restore the site from the backup.
Then, I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
April 11, 2025 at 3:41 pm #16923581
Thanks for your reply. It looks like the copy you sent over is the one that is already broken. Could you restore this site hidden link and then create a new duplicator package for me?
Then, I will troubleshoot this further for you.
April 11, 2025 at 7:48 pm #16924308
kristoferJ-2
If you said I should unfilter media files then you cant see the media files via backup? If needed I can create test domain if its easier to test also!
April 11, 2025 at 7:49 pm #16924309
kristoferJ-2
So on test domain its possible to test absolutelly everything, I can share wp access, ftp access and mysql access. Let me know.
April 14, 2025 at 9:42 am #16928076
Thanks for your reply. Ok, please share access to your test domain so that I can recheck this. I've enabled the private reply option for you and please backup everything.
April 15, 2025 at 4:41 pm #16935547
Thanks for your patience.
I've downloaded the correct copy of the original site and I will check and come back to you as quickly as possible.
April 16, 2025 at 7:04 pm #16940996
Thanks for your patience. I cannot find any solution for this, and I will escalate this to our 2nd Tier Support for further assistance. I will come back to you once I've feedback.
The topic ‘[Closed] Problem with languages – emergency!’ is closed to new replies.
