| - | 8:00 – 13:00 | 9:00 – 13:00 | 9:00 – 13:00 | 8:00 – 12:00 | 8:00 – 12:00 | - |
| - | 14:00 – 17:00 | 14:00 – 18:00 | 14:00 – 18:00 | 13:00 – 17:00 | 13:00 – 17:00 | - |
This topic contains 32 replies, has 0 voices.
Last updated by Bruno Kos 4 months, 1 week ago.
Assisted by: Bruno Kos.
| Author | Posts |
| November 11, 2025 at 9:06 am | |
tomaszK-61 |
Background of the issue: I've read that the error may be related to the lack of a multi-currency agreement with PayU, but apparently there's an option to automatically convert euros to Polish zloty (PLN). Unfortunately, I can't figure out how to do this. There's also a problem with shipping prices – it converts the price from złoty to euro 1:1. For example, if shipping costs 20 PLN, it converts it to 20 euros, not 5. I see the "Enable automatic exchange rates" option unchecked - maybe that's the problem? Only there, an external API is required everywhere. I will be happy to provide login information for the website. I'll send screenshots. I would like to contact a human being, please. Symptoms: Questions: |
| November 11, 2025 at 10:05 am #17565602 | |
Bruno Kos WPML Supporter since 12/2018
Languages: English (English ) German (Deutsch ) French (Français ) Timezone: Europe/Zagreb (GMT+02:00) |
Before we proceed with testing this in sandbox (which I've already prepared), can you update these plugins on your site: And check if the gateway works after this? |
| November 11, 2025 at 10:24 am #17565719 | |
tomaszK-61 |
All plugins updated |
| November 11, 2025 at 3:56 pm #17567660 | |
Can you tell me if the gateway works after the updates? If still not working, can you install PayU payment gateway here: And check if the gateway is missing when trying to order something in the English version of the site? If missing here as well, let me know and I will check this with our compatibility team. |
| November 11, 2025 at 4:40 pm #17567855 | |
tomaszK-61 |
I checked after the update, and the problem is still the same. The Polish version is fine, but the English version doesn't show the PayU payment method with euros. It also still converts shipping prices 1:1 euro to the same amount as the Polish zloty. I don't understand what I'm supposed to install on awesome-mandolin. The webstie must be accepted by PayU for payments to work. It's accepted on coupledansant.com. |
| November 12, 2025 at 8:41 am #17569316 | |
Just to confirm my understanding — does this mean the test site (hidden link) can’t be used for PayU payments because the domain itself needs to be registered and accepted by PayU? Since coupledansant.com is already approved, I assume payments will only work there unless the staging URL is also added to PayU’s system. Do you have the option to add this additional domain in your PayU account? If not, please let me know so I can discuss possible solutions with our developers. |
| November 12, 2025 at 3:24 pm #17571678 | |
tomaszK-61 |
From what I understand, the domain must be accepted by PayU and coupledansant.com is confirmed - you can do tests there, I made a backup, I can also provide FTP login and database access. |
| November 13, 2025 at 12:25 pm #17574762 | |
I’m checking this with our second-tier team and will keep you updated. |
| November 13, 2025 at 12:42 pm #17574840 | |
tomaszK-61 |
Ok, I understand. |
| November 13, 2025 at 1:34 pm #17575033 | |
tomaszK-61 |
I received this response from PayU support: "Yes, in order to enable payments in foreign currencies, you must sign an amendment to the Agreement regarding currency payments." So, am I understanding correctly that the English version of the payment method will only be available once the multi-currency agreement is signed? Isn't there a way to automatically convert from euro to złoty? What about shipping costs? Why is it converting 1:1 from złoty to euro? I'm attaching a screenshot to this message. Could you please help me translate the highlighted areas? |
| November 13, 2025 at 3:59 pm #17576029 | |
We checked the PayU settings and saw that the EUR configuration section is completely empty: To confirm the cause, we temporarily copied the same values used for PLN into the EUR fields, and PayU immediately appeared on the frontend: This shows that PayU requires separate account details / configuration keys specifically for EUR payments. These EUR keys need to be created or obtained from your PayU merchant panel (in the “Configuration keys” section) and then added to the EUR settings in WooCommerce. Once those EUR keys are entered, PayU will start working for EUR payments as expected. Can you check the above? |
| November 13, 2025 at 5:25 pm #17576405 | |
tomaszK-61 |
Thank you very much for checking, so I do indeed need to upgrade my PayU account to include a multi-currency account. I'm signing a contract with PayU now and will get back to you with an answer. |
| November 13, 2025 at 5:27 pm #17576412 | |
tomaszK-61 |
Will it then also calculate shipping prices correctly? Can you help translate the phrases I highlighted in the previous screenshot? |
| November 14, 2025 at 9:57 am #17578148 | |
About these strings, can you check https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/#register-admin-and-setting-strings-for-translation? Can you find them like this? And if so, add them to string translation and translate? As for the shipping issue, I can see that you have 1:1 conversion rate, can you check this? It is set on hidden link |
| November 14, 2025 at 10:59 am #17578543 | |
tomaszK-61 |
Until now, the shipping cost was converted 1:1 (PLN 1 = EUR 1) and it should be PLN 1 = EUR 0.24. Can you check it to make sure it converts correctly? |
The topic ‘[Closed] Problem with payments in a second language’ is closed to new replies.
