Supporter timezone: Africa/Cairo (GMT+02:00)
Last updated by Osama Mersal 1 month, 2 weeks ago.
Assisted by: Osama Mersal.
January 31, 2026 at 10:54 am #17780016
martinM-28
One of the languages ​​we use is Italian. Unfortunately, when using this language, we have a big problem in the checkout. The checkout and the ordered items appear, including the order button. After a few milliseconds, the order button disappears. It disappears completely. Instead, a window opens with the text gdpr. Moreover, the text is somehow damaged. It does not contain the exact text of the gdpr. Only part of it. So in the Italian language, the order cannot be closed at that moment. Which is a real problem. This does not happen with other languages ​​we use.
February 1, 2026 at 11:02 am #17781139
Osama Mersal
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
❌ Please back up your database and website ❌
✙ I need your permission to deactivate and reactivate the plugins and themes, and change site configurations. This is also why the backup is critical.
Osama
February 2, 2026 at 10:37 am #17783276
Osama Mersal
1) Thanks for the access details. Please let me know when you get a reply from the OTP plugin support team.
2) Please run the following test and let me know the result.
1- Deactivate all the plugins except WPML CMS, String Translation, WooCommerce, WooCommerce Multilingual, and the OTP plugin.
2- Switch to a WordPress default theme like Twenty Twenty-one.
3- Check the Italian checkout page.
❌ Please back up your database before the above test ❌
Osama
February 2, 2026 at 10:48 am #17783311
martinM-28
Yes, thank you. I will do it sometime in the next 24 hours.
February 2, 2026 at 10:49 am #17783316
Osama Mersal
Sure, take your time and let us know the test result.
Osama
February 2, 2026 at 11:04 am #17783348
martinM-28
The MiniOrange team has made some adjustments and now everything seems to be fine. Thank you, I'll get back to you later.
Martin Micanek
February 2, 2026 at 11:08 am #17783352
Osama Mersal
Hi Martin,
Thanks for your update. Please don't hesitate to contact us if you still face the same issue.
Osama
The topic ‘[Closed] Problem with the “order” button in Italian’ is closed to new replies.
