If you're experiencing issues with the WooCommerce shopping cart not adding more than 2 products or forgetting products when the WooCommerce Multilingual & Multicurrency plugin is enabled, this might be due to a plugin conflict.
We recommend following the steps outlined in the WPML support forum to resolve this issue. You can find the detailed steps here: WPML support forum thread.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should these steps not resolve your issue, please do not hesitate to open a new support ticket with us for further assistance at WPML support forum.
Last updated by peterK-126 1 year ago.
August 9, 2024 at 12:26 pm
peterK-126
I am experiencing an issue with the WooCommerce Multilingual & Multicurrency plugin on my site hidden link. When the plugin is enabled, the shopping cart does not function correctly.
If the plugin is enabled, the WooCommerce shopping cart will not add more than 2 products and forgets the rest. The cart usually shows only one product even though I added more. The issue is resolved when the extension is turned off.
Why does the WooCommerce shopping cart not add more than 2 products when the WooCommerce Multilingual & Multicurrency plugin is enabled?
How can I fix the issue where the shopping cart forgets products when the WooCommerce Multilingual & Multicurrency plugin is enabled?
August 9, 2024 at 1:30 pm
August 12, 2024 at 8:06 am #16060955
peterK-126
Hello !
This is what my cart looks like after adding 4 products. It also makes the error in incognito mode. If I turn off the extension everything works fine. The error also occurred on another computer.
Thanks for your help in advance as well.
best
Peter
August 12, 2024 at 9:34 am #16061425
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
Can I disable/enable plugins/themes on your site?
Also, the login details are not workings, can you please check and provide me in the next private reply.
August 12, 2024 at 10:03 am
August 12, 2024 at 11:15 am #16061871
Shekhar Bhandari
Hello there,
Can I disable/enable plugins/themes on your site? Can you confirm that you have a backup?
Look forward to your reply.
August 12, 2024 at 12:19 pm #16062127
peterK-126
HEllo !
Yes i confirm I have back up. Thank you !
Peter
August 12, 2024 at 12:43 pm #16062216
Shekhar Bhandari
Hello there,
I followed the steps as mentioned here and the issue seems to be fixed, https://wpml.org/forums/topic/items-in-the-cart-are-being-deleted/#post-14493585
Can you please confirm.
August 12, 2024 at 1:04 pm #16062350
peterK-126
Hello !
Super!!! The problem is solved, but for some reason the currency toggle appears twice. See screen save.
best regards
Peter
August 12, 2024 at 1:20 pm #16062402
Shekhar Bhandari
Hello there,
The switcher is showing in place of main menu as it's added on primary menu with shortcode, you can remove the shortcode from the primary menu to solve it: hidden link
August 12, 2024 at 1:41 pm #16062494
peterK-126
Hello !
I only added it to the microwidget, that is why I didn't understand. But that's okay.
Thanks for the solution and your work.
Peter
