If you're experiencing an issue where content translated in Norwegian is displaying in English instead, it might be due to a bug we've identified.
We recommend the following steps to address this issue:
1. Navigate to WPML > Settings > Custom XML Configuration in your WordPress dashboard.
2. Add the following XML configuration and save:
<wpml-config>
  <elementor-widgets>
    <widget name="jet-form-builder-form">
      <fields>
        <field type="post-ids" sub-type="jet-form-builder">form_id</field>
      </fields>
    </widget>
  </elementor-widgets>
</wpml-config>
3. Resave the original page and re-translate the page.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Additionally, please feel free to open a new support ticket with us for further assistance at WPML Support Forum.
Last updated by Dražen 3 months, 1 week ago.
Assisted by: Dražen.
December 17, 2025 at 11:18 am
lasseE-3
I got this translatet but now it show up as english on norwegian.
December 17, 2025 at 11:56 am #17670792
Dražen
I was able to reproduce the same issue and can confirm that it is a bug.
I’ve now escalated this to our compatibility team for further investigation.
I’ll update you as soon as I have more information.
Dražen
December 18, 2025 at 6:48 am #17673248
Dražen
we have checked, please follow next steps:
- Go to WPML > Settings > Custom XML Configuration in your WordPress dashboard.
- Add the following XML configuration and save:
<wpml-config>
  <elementor-widgets>
      <fields>
      </fields>
    </widget>
</wpml-config>
Then resave the original page and re-translate the page.
Drazen
