Problem: You are trying to translate Elementor heading titles and paragraphs on your site but the translations are not displayed, only the original language. Solution: 1) Translate the template ID via WPML-> String Translation. After this step, the strings should work correctly in both languages. 2) To translate the related listings widget, add the following XML code in WPML-> Settings-> XML tab:
Please verify if the translations are now correctly displayed.
If this solution does not resolve your issue or seems outdated, we recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Please edit the translated page/template that you use this listing item using Elementor and make sure that it uses the translated listing item.
If it uses the correct listing item, I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Preferably to a test site where the problem has been replicated.
Unfortunately, strings do not work as expected. Default site language is polish, but heading titles and text in screenshot are in english. They were suppose to be english only in english version. Now they are english in both versions.
