If you're experiencing a PHP Fatal error when updating a product variant in WooCommerce that exists only in a non-main language, it might be due to the variant's original ID missing in the database. This issue can occur if the original variant was removed while WPML was disabled or due to an external process, leading to potential database corruption.
We recommend running the ghost cleanup process in WPML to resolve this issue. Please navigate to:
WPML → Support → Troubleshooting
Then, select: "Remove ghost entries from the translation tables".
This action should help clear any discrepancies in the database related to missing original IDs.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should the problem persist, please do not hesitate to open a new support ticket at WPML support forum for further assistance.
Last updated by geertP 4 months, 3 weeks ago.
Assisted by: Bruno Kos.
January 27, 2025 at 12:58 pm #16637777
geertP
I am working on a site at hidden link where we created a custom sync to import and update WooCommerce products using data from an external PIM. The sync works well except when a product variant is only available in a language that is not the main language. We use the wpml_copy_post_to_language hook to translate a product or a product variant and after copying, we update the content to the correct language.
We encounter a PHP Fatal error: Uncaught TypeError: array_filter(): Argument #1 ($array) must be of type array, bool given in /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/classes/translation-jobs/class-wpml-element-translation-package.php:319 when updating a variant that exists only in a non-main language.
Stack trace:
#0 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/classes/translation-jobs/class-wpml-element-translation-package.php(319): array_filter(false)
#1 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/classes/translation-jobs/class-wpml-element-translation-package.php(92): WPML_Element_Translation_Package->add_custom_field_contents(Array, NULL, Array, Array)
#2 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/inc/actions/wpml-tm-action-helper.class.php(13): WPML_Element_Translation_Package->create_translation_package(NULL)
#3 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/inc/actions/wpml-tm-post-actions.class.php(72): WPML_TM_Action_Helper->create_translation_package(‘5841’)
#4 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/inc/functions-load-tm.php(947): WPML_TM_Post_Actions->save_post_actions(5844, Object(WP_Post), 9)
#5 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/class-wp-hook.php(324): wpml_tm_save_post(5844, Object(WP_Post), 9)
#6 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(‘’, Array)
#7 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/plugin.php(517): WP_Hook->do_action(Array)
#8 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/inc/post-translation/wpml-post-translation.class.php(213): do_action(‘wpml_tm_save_po...’, 5844, Object(WP_Post), false)
#9 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/inc/post-translation/wpml-frontend-post-actions.class.php(61): WPML_Post_Translation->after_save_post(‘19003’, Array, ‘nl’, NULL)
#10 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/class-wp-hook.php(326): WPML_Frontend_Post_Actions->save_post_actions(5844, Object(WP_Post))
#11 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(NULL, Array)
#12 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/plugin.php(517): WP_Hook->do_action(Array)
#13 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/post.php(5060): do_action(‘save_post’, 5844, Object(WP_Post), true)
#14 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/post.php(5162): wp_insert_post(Array, false, true)
#15 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/woocommerce/includes/data-stores/class-wc-product-variation-data-store-cpt.php(247): wp_update_post(Array)
#16 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/woocommerce/includes/class-wc-data-store.php(196): WC_Product_Variation_Data_Store_CPT->update(Object(WC_Product_Variation))
#17 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/woocommerce/includes/abstracts/abstract-wc-product.php(1469): WC_Data_Store->update(Object(WC_Product_Variation))
#18 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/inriver-sync/functions/woocommerce/product-variation.php(44): WC_Product->save()
#19 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/inriver-sync/functions/woocommerce/product.php(134): set_product_variation(5843, Array, 5844)
#20 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/inriver-sync/functions/xml.php(32): set_wc_product(Array, 5843)
#21 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/inriver-sync/functions/sync.php(38): xml_product_sync(‘/data/sites/web...‘)
#22 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/themes/ics/templates/tpl-product-sync.php(13): product_sync()
#23 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/themes/ics/base.php(80): include(‘/data/sites/web...‘)
#24 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/template-loader.php(106): include(‘/data/sites/web...‘)
#25 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-blog-header.php(19): require_once(‘/data/sites/web...‘)
#26 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/index.php(17): require(‘/data/sites/web...’)
#27 {main}
thrown in /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/classes/translation-jobs/class-wpml-element-translation-package.php on line 319
The inriver-sync plugin is our custom sync.
The error happens when we updated a value of the variant (for example the title) en we call the WC Product Variant save-function from woocommerce.
I guess there is a WPML hook that gets triggered when that function is called.
We use the wpml_copy_post_to_language hook to translate a product or a product variant and after we copied the product or variant, we update the content to the correct language.
Is it not possible to have different variants in a product in different languages or is there something we do wrong?
Is this just not possible when coding a sync like this?
January 28, 2025 at 9:24 am #16640483
Bruno Kos
It seems the issue arises due to incomplete or unexpected data when product variants exist only in non-main languages, leading to WPML hooks failing during synchronization.
To investigate further, could you provide us with access to a staging site where such products with errors are present, the code triggering the issue, and database access (e.g., via a plugin like https://wordpress.org/plugins/pexlechris-adminer/?
It would be helpful if you could share steps or a method to reproduce this issue, such as calling the relevant function.
Bruno Kos
January 30, 2025 at 12:06 pm #16651256
Bruno Kos
I am checking this with our 2nd tier and will keep you posted.
January 31, 2025 at 8:16 am #16654189
Bruno Kos
Based on our initial review, it appears that the issue may be related to how the custom plugin handles translation packages for product variations. To better understand and assist you effectively, could you please provide the following details?
1. Can you share more information about the custom plugin in use? Does it manage variations in any specific way that could interfere with WCML’s automatic handling?
2. If possible, please outline the steps that lead to the issue so we can try to replicate it on our end.
3. If convenient, a visual reference of the issue could help us diagnose the behavior more quickly. You can record a video using tool such as hidden link.
February 3, 2025 at 10:28 am #16662210
geertP
Below you can find our answers to your questions:
In our custom plugin, we do the following steps
We create or get an existing product (depending on if there already is a product with the SKU)
If a new product, we use the WPML-hook ‘wpml_copy_post_to_language’ to copy the product to the language(s) where it should also be available.
If product already exists, we get the product by SKU in each language an update the content fields
We do the same for each variant as well
You can see all the settings we update for a product variant in ‘wp-content/plugins/inriver-sync/functions/woocommerce/product-variation.php’
Like I mentioned in the previous mail, you can replicate the issue in the sync as followed:
The sync can be triggered manually by going to: hidden link
When the problem occurs, the sync stops on the XML-file where the problem occurs.
The XML-file where the problem occurs will not be moved to the done folder on the mp-server.
If you trigger the sync again, it will try to continue with that file and crash again so you don’t have to move the files during debugging.
There is no visual reference since everything works in the background. The only thing we have is the error log where we get the next error:
[28-Jan-2025 11:53:32 UTC] PHP Fatal error: Uncaught TypeError: array_filter(): Argument #1 ($array) must be of type array, bool given in /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/classes/translation-jobs/class-wpml-element-translation-package.php:319
Stack trace:
#3 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/inc/actions/wpml-tm-post-actions.class.php(72): WPML_TM_Action_Helper->create_translation_package('5841')
#6 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters('', Array)
#8 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/inc/post-translation/wpml-post-translation.class.php(213): do_action('wpml_tm_save_po...', 5844, Object(WP_Post), false)
#9 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/sitepress-multilingual-cms/inc/post-translation/wpml-frontend-post-actions.class.php(61): WPML_Post_Translation->after_save_post('19003', Array, 'nl', NULL)
#13 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/post.php(5060): do_action('save_post', 5844, Object(WP_Post), true)
#21 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/plugins/inriver-sync/functions/sync.php(38): xml_product_sync('/data/sites/web...')
#23 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-content/themes/ics/base.php(80): include('/data/sites/web...')
#24 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-includes/template-loader.php(106): include('/data/sites/web...')
#25 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/wp-blog-header.php(19): require_once('/data/sites/web...')
#26 /data/sites/web/website-in-progressbe/subsites/aquaplan2024.website-in-progress.be/index.php(17): require('/data/sites/web...')
#27 {main}
This is the best implementation we could find with the limited documentation for a custom integration. If there is a better way to implement something like this, we would love to hear about it.
February 3, 2025 at 2:15 pm #16663233
Bruno Kos
Thank you for additional info.
To troubleshoot this problem, I'll install the Duplicator plugin and generate packages for further debugging purposes. I'll ensure to exclude all media files to maintain a minimal package size. You can find more information about the process here: [link](https://wpml.org/faq/provide-supporters-copy-site/). Please confirm if this approach is acceptable to you.
Our 2nd tier will have to debug this locally to see why it fails.
February 3, 2025 at 2:28 pm #16663339
geertP
This is ok, thanks
February 4, 2025 at 7:23 am #16665049
Bruno Kos
This has been escalated to our 2nd tier team team and may take some debugging time, I'll get back to you as soon as I have any news or questions for you.
February 6, 2025 at 12:34 pm #16675513
Bruno Kos
The system triggered a process that iterates over variations. During this, it attempted to save a variation with ID **5844**.
This variation corresponds to the **NL language code** and is expected to have an original variation ID (for **nl-be**) with ID **5841**.
However, the issue arises because **ID 5841 does not exist in the database**, meaning its fields cannot be retrieved. While this variation exists in the secondary language, it should still be treated as the original rather than a translation.
This suggests that the original variation was removed through a method unknown to **WPML**, possibly when **WPML was disabled** or due to an external process.
**Evidence:**
Running the command to fetch both IDs confirms the issue:
- Only **ID 5844** (the translation) is listed.
- **ID 5841** (the original) is missing.
This indicates potential **database corruption**, which can be resolved by running the **ghost cleanup process** in WPML.
**Solution:**
Please navigate to:
**WPML → Support → Troubleshooting**
Then, select: **"Remove ghost entries from the translation tables"**
Could you try this and confirm if it resolves the issue?
February 10, 2025 at 11:20 am #16686592
geertP
Thanks for the suggestion, that did the magic!
