Last updated by Kor 1 year, 11 months ago.
June 14, 2023 at 12:06 pm #13824825
alexisK-2
the coupon code (limited10) doesnt work in English. WordPress, Woo and Theme is all up to date.
June 15, 2023 at 10:00 am #13831117
WPML Supporter since 08/2022
I would need to take a closer look at your site. So I would need to request temporary access (WP-Admin and FTP) preferably to a test site where the problem has been replicated if possible in order to be of better help and check if some configurations might need to be changed
IMPORTANT: Please, note, a backup is required for security reasons, and to avoid any data loss, you can use the https://wordpress.org/plugins/updraftplus/plugin for these backup needs.
Your following answer will be private, which means only you and I have access to it.
✙ I would need your permission to de-activate and re-activate Plugins and the Theme and to change configurations on the site if required. This is also a reason the backup is critical.
The topic ‘[Closed] Problem with woocommerce coupon code in second language’ is closed to new replies.
