Hello, I have a problem with displaying product color variants with YITH WooCommerce Color and Label Variations plugin.
On the Polish site, everything works fine, but when I'm switching it to English, color swatches doesn't work.
https://embrofly.com/ - Polish version
https://embrofly.com/en/ - English version
Specific product - https://embrofly.com/en/sklep/polo-shirts/polo-cotton/
YITH plugins add a color picker in the Attribute section whose value doesn't get copied to the translated attribute. Need to manually add the value for translated attributes. Please check the response below-
https://wpml.org/forums/topic/problem-with-yith-woocommerce-color-and-label-variations-plugin/#post-13899229
Last updated by tomaszW-20 1 year, 11 months ago.
June 26, 2023 at 10:11 am #13894307
tomaszW-20
hidden link - Polish version
hidden link - English version
Specific product - hidden link
June 27, 2023 at 5:45 am #13899229
Prosenjit Barman
WPML Supporter since 03/2023
Hi There,
Thanks for contacting WPML Support. I would be happy to assist you in this matter.
I understood the issue you're having. For your information, the plugin that you're using to improve the style of variation is not currently listed in our compatible plugin list. Therefore, there is a chance that the feature belonging to this plugin may not work expectedly in a multilingual environment.
However, I checked and was able to replicate the same scenario on my end too. It seems the value assigned to the attribute terms(added by the plugin) isn't getting copied to other languages which is why, the variations are not showing properly for the translated products.
The issue can be solved by including the value manually in the translated variations. In order to understand the procedure, please check the video mentioned below.
- hidden link
I hope it will help. But, to make it compatible with WPML, you can reach out to the author and request them to add the compatibility. As most of their products are already compatible with WPML, I hope they will consider your request and work on adding compatibility.
Please let me know if there is anything else you need help with. I will be happy to assist you.
Best Regards,
Prosenjit
