Last updated by Kor 5 months ago.
October 21, 2025 at 9:42 am #17502313
michaelR-151
Thank you Kor.
4 things:
1.
Thanks. Can you see that the 50.000 words was added, and they was used? Is this use amount normal for 1.200 items x 2 languages? Could there be an error?
2.
The cogwheel in the top is stuck running again, for the aprox. 8. time. I would like very much to get rid of this error. Can you go deeper and fix this for good? See 2 x pics. Running and running and running - again!
3.
One word keeps going back to danish, but was translated to spansih 3 times, but keeps going back. Look:
Original danish: Søg ...
Spanish: Buscar ...
English: Search ...
I have put this in the Glossary, to prevent "Buscar ..." to being changed to "Søg ...", must be "Buscar ..." and I have done what should be needed to keep translations. Look in Glossary or give me a hint to fix this.
4.
I have problems with Google Merchant Center and WPML. Now no items are approved at GMC. This is important, as no approved items hurts our sale.
Question: Does WPML and 3 languages work well with the Google for WooCommerce plugin? If YES, then please tell me what to change to have the items works and get approved. If NO then please tell me if:
"Product Feed Manager For WooCommerce – Sell on 200+ Online Marketplaces" or
"CTX Feed – WooCommerce Product Feed Manager" or
"Product Feed for Google Shopping, Microsoft Advertising and 40+ Channels for WooCommerce Merchant"
... will do the job? Fine if I do not need a plugin more, but if I do need it, I better get it fast, as dead items is expensive.
Same user + password as last time.
Regards.
Michael
October 22, 2025 at 8:36 am #17505968
Thanks for your patience. I've performed a search and it looks like "Google for WooCommerce plugin" is not tested or compatible with WPML. But when I checked this plugin "Product Feed Manager for WooCommerce", it is fully compatible with WPML https://wpml.org/plugin/product-feed-manager-for-woocommerce/ . Would you like to try this one or maybe try this one? https://wpml.org/plugin/woocommerce-google-product-feed/
October 22, 2025 at 7:26 pm #17510061
michaelR-151
Hi Kor.
I could not wait so I bought plugin CTX Feed, and I works very good, also with WPML.
So this one is solved.
Regards
Michael
October 23, 2025 at 6:37 am #17510911
Good to know. Feel free to open a new ticket if you need anything further.
October 23, 2025 at 2:43 pm #17512959
michaelR-151
Yes, I think it is very well made. Runs very fine.
And it is also recomended by WPML:
https://wpml.org/plugin/ctx-feed-pro/
October 23, 2025 at 3:25 pm #17513156
Thanks for the feedback. I will check your other tickets. Closing this one.
The topic ‘[Closed] Problems with Google Merchant Center and WPML’ is closed to new replies.
