The client is experiencing an issue where the language switcher on their website does not direct to the translated page but instead redirects randomly. This problem is due to a conflict with the WPResidence theme's caching method, which incorrectly caches the language switcher links.
1. As a temporary fix, we recommend adding the following code to the functions.php file of your theme to clear the WPResidence menu transients on each page load, ensuring the menu updates correctly and displays the appropriate language links:
 * Zap every WP Residence menu transient on each page load.
 * The target string is unique enough that a single LIKE works.
function cleanup_wpresidence_menu_transients() {
    global $wpdb;
    $like = '%' . $wpdb->esc_like( 'wpestate_wpresidence_primary_menu_complete' ) . '%';
    $wpdb->query(
        $wpdb->prepare(
            "DELETE FROM {$wpdb->options}
             WHERE option_name LIKE %s",
            $like
add_action( 'init', 'cleanup_wpresidence_menu_transients' );
Ensure you perform a full site backup before implementing this code. After adding the code, clear all types of caches to check if the issue persists.
2. Additionally, the WPResidence theme team has acknowledged this bug and plans to include a fix in a future theme update. Meanwhile, they suggest disabling the Theme Menu Cache as a temporary workaround. You can find instructions on how to do this here: Disable WP Residence Cache.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If needed, please open a new support ticket at WPML Support Forum for further assistance.
Last updated by Bigul 7 months ago.
Assisted by: Bigul.
April 30, 2025 at 2:43 pm
mathiasA-14
I am trying to change the language of any page on my website. The issue can be seen on this page: hidden link
The language switcher button sends me to any page, and it changes randomly instead of showing the translated page.
Why does the language switcher not direct to the translated page?
How can I fix the random page redirection issue with the language switcher?
April 30, 2025 at 4:24 pm #16984927
Bigul
The issue still exists after the initial checks. We would like to confirm whether there are any server-side caches in place. If so, it would be great if you could clear them, as the issue temporarily resolves for a few seconds when I purge the SG caches.
Bigul
April 30, 2025 at 9:57 pm #16985308
mathiasA-14
I use siteground and it has different types of cache. I purged all the cache and it is still malfunctioning.
May 1, 2025 at 3:42 am #16985510
Bigul
Thank you for the updates. Please allow me to make a copy of your site using the Duplicator plugin (https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server. So we can troubleshoot the issue without affecting your live site.
Bigul
May 1, 2025 at 12:12 pm #16986512
mathiasA-14
Hi Bigul!
Yes, I allow you to do so. Do you need anything else from me?
May 4, 2025 at 4:47 am #16992681
Bigul
Thank you for the permission. I made a copy of the site, but the issue remains on my local copy after the initial troubleshooting steps. So, I am consulting with our team for an expert opinion now. We will get back to you as soon as possible. Please wait.
Bigul
May 6, 2025 at 6:31 pm #17003229
mathiasA-14
Hello, any news? The website has a lot of traffic and it is not good to have this problem. If you can't fix the widget maybe we can find another solution, but let's do something please, my client is really upset.
May 7, 2025 at 6:06 am #17004348
Bigul
We are still working on this issue. The ticket has been escalated to our second-tier team for further debugging. We will get back to you as soon as possible. Please wait.
Bigul
May 7, 2025 at 3:51 pm #17007627
Bigul
This bug is happening becuase of a conflict with the WpResidence caching. The theme uses a custom caching method for menus by storing them in transients (temporary data that lasts for about 4 hours). When someone visits a page, the menu (including the language switcher) is saved this way, so the same menu links are shown on all other pages, even if the language links are no longer correct.
As a workaround, we have used the following code to clear these transients on every page load, so the menu updates correctly each time and shows the right language links. Our compatibility team is still reviewing it for a permanent solution.
	global $wpdb;
	$wpdb->query(
		$wpdb->prepare(
			$like
So, please add this code in the functions.php file of the theme (at the bottom of the file, like the attached image) after a full site backup (mandatory). Then, clear all types of caches and make sure the bug exists or not.
Bigul
May 11, 2025 at 12:38 am #17019603
mathiasA-14
Thanks, I am attentive to the news to solve the problem definitively.
May 12, 2025 at 6:09 am #17021008
Bigul
Thank you for the feedback. We have released an errata for this and are expecting a fix from the theme author in the future.
https://wpml.org/errata/wp-residence-main-menu-language-switcher-shows-wrong-urls/
We will update you soon when we have an update from our compatibility team about this.
Bigul
May 12, 2025 at 9:28 pm #17024669
mathiasA-14
Ok, so I am looking forward to hearing from you soon. Thank you!
May 13, 2025 at 7:03 am #17025337
Bigul
Thank you for the updates. We will get back to you as soon as we have feedback. Please stay tuned.
Bigul
May 28, 2025 at 7:14 am #17081509
Bigul
We have received an update from the WPResidence theme team. The fix for this bug will be included in a future version of the theme. In the meantime, they have suggested a temporary workaround: disabling the Theme Menu Cache.
Bigul
July 16, 2025 at 3:28 pm #17242896
Bigul
We have an update on this. The WP Residence developers have confirmed that this issue has been fixed in their latest version (5.2.0).
Please update the theme after taking a full site backup and check if the issue is resolved. Refer to the following URL for more details:
Bigul
