Last updated by urbanT-2 1 year, 3 months ago.
Assisted by: Waqas Bin Hasan.
| Author | Posts |
| January 30, 2025 at 12:57 pm #16651529 | |
urbanT-2 |
Background of the issue: Symptoms: Issue #2 – Images Not Loading Consistently: Some product images do not load properly in the store. They appear intermittently—sometimes they display, sometimes they don’t. I tried using Force Regenerate Thumbnails, which temporarily fixed the issue, but it returned. I verified that the image files are not corrupted. Questions: |
| January 31, 2025 at 9:23 am #16654526 | |
urbanT-2 |
The problem is still not solved. |
| January 31, 2025 at 9:49 am #16654750 | |
Marcel Supporter
Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: Europe/Vienna (GMT+02:00) |
Hi, before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process. Please share the debug.log file from your site so we can identify the cause of the Fatal Error 500. You can activate it as described here. Additionally, note that your WPML setup does not meet the recommended system requirements for WP_MEMORY_LIMIT. Your server has a 256MB PHP memory limit, but WordPress is currently restricted to 40MB, which may be contributing to the issue. Best Regards |
| January 31, 2025 at 1:45 pm #16655874 | |
urbanT-2 |
I have increased the WordPress memory limit to 512M. Now I don't see the problem with the images anymore from my part, can you please do a check from your part, if any images are not showing up. I don't see the Error 500 anymore, but the problem with the checkout is still there. |
| February 1, 2025 at 4:31 pm #16658603 | |
urbanT-2 |
I did some digging and found that the endless loading spinner on the checkout page is caused by the "WooCommerce Multilingual & Multicurrency" plugin. When inspecting the page in a non-default language, I encountered a 500 error at the following endpoint: URL: hidden link However, after disabling the "WooCommerce Multilingual & Multicurrency" plugin, the checkout page loaded normally. |
| February 3, 2025 at 10:57 am #16662323 | |
urbanT-2 |
Hello, is anyone there? |
| February 4, 2025 at 8:45 am #16665295 | |
Waqas Bin Hasan WPML Supporter since 05/2014
Hi, Thank you for contacting the support, I'm assigned this ticket and 'll try my best to help you resolve the issue. Before proceeding further, as it was requested by my colleague, can you enable debugging in your site? See https://wpml.org/documentation/support/debugging-wpml/ for details. Once enabled, retry the checkout. This will log the errors in the debug.log file which you can upload somewhere (i.e. hidden link) and share the download link for investigation. Further, I'll recommend to check the following as well: 1) Take a full backup of your site and database before proceeding. It is highly advised to try these on a dev or staging site first, so your live site isn't compromised. Please let me know your findings and I'll try my best to help you further on the matter. Regards. |
| February 4, 2025 at 9:37 am #16665759 | |
urbanT-2 |
I fixed it myself. Thank you. |
