Last updated by Shekhar Bhandari 5 months ago.
November 19, 2025 at 5:42 am #17589954
Luca Petrocchi
I am trying to update variable products in Italian on my WordPress site using WPML. However, after making updates such as changing the price or updating an image, the variations in Italian break. This issue sometimes occurs immediately or after 5 to 10 minutes. The language of the variation may disappear, or the format/attribute value may be removed. In some cases, the Italian language attribute is completely removed from the product's attribute list, requiring manual re-addition to recreate the variation. I have already tried all available troubleshooting tools in WPML and WCML settings, disabled caching layers, downgraded plugins, and performed a clean installation of WPML, but the issue persists. Here are some screenshots of the problem: hidden link, hidden link, hidden link, hidden link, hidden link, hidden link. The issue can be seen on this page: hidden link.
Product attributes and variations in Italian disappear or break after product updates. The language of the variation may disappear, or the format/attribute value may be removed. The Italian language attribute is completely removed from the product's attribute list.
Could you please assist us in identifying the root cause and resolving this problem?
November 19, 2025 at 6:13 am #17589965
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
Thank you for contacting WPML support. I'd be happy to assist you on this issue.
Isn't Italian the default language of the site, if yes, can you disable WPML and see if the problem appears even without WPML?
Further, We've recently rolled out a new version of WPML plugins. Could you please update your plugins to the latest version and inform me if it resolves the issue?
Our WPML updates are distributed gradually. If your websites haven't received this update yet, please be patient, and you should see it within a few days.
If you want to expedite the process and receive the update immediately, follow these steps:
1. Go to the Plugins → Add New Plugin.
2. Click on the Commercial tab.
3. Then, click the "Check for updates" button.
https://wpml.org/wp-content/uploads/2020/04/wpml-force-plugin-update-1.png
Please remember to create a backup before updating, as a precaution.
Look forward to your reply.
November 19, 2025 at 8:16 pm #17593462
Luca Petrocchi
Hello Shekhar,
Thank you for your reply.
Yes, the default language of the site is Italian.
We have already tested disabling WPML, and the issue does not occur without WPML active — it only happens when WPML is enabled.
Regarding the plugin versions: at the time the issue first appeared, we had already tried downgrading the WPML-related plugins to earlier versions. After that, we updated them again to the latest available release, and the problem continued to appear even after re-updating.
Let me know if you need access to the backend or further tests from our side.
November 20, 2025 at 4:32 am #17593821
Shekhar Bhandari
Hello there,
To debug this issue further, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
Note:
November 24, 2025 at 4:43 am #17602826
Shekhar Bhandari
Hello there,
I tried to update the price on this product and the variations are there: hidden link
I waited for 10 minutes, may be I am missing something, can you record the steps that you are performing so I can test this further?
November 24, 2025 at 7:41 pm #17606116
Luca Petrocchi
Hello there,
I just create the variants of my variable products, set price and images and then i proceed to publish them. I don't make any further steps.
Also, these are the products that once again are hit by this issue. You can try to adjust them and see what happens next.
Thanks for your help.
November 25, 2025 at 6:50 am #17606633
Shekhar Bhandari
Hello there,
I tried to make updates to this product: hidden link
Waited for few hours but still the variations are there and aren't disappearing.
Can you check with this product yourself once and see if you can reproduce the error?
The topic ‘[Closed] Product attributes and variations disappear after product updates’ is closed to new replies.
