Last updated by jackyK-2 4 years, 7 months ago.
Assisted by: Paola Mendiburu.
June 29, 2020 at 9:23 am | |
jackyK-2 |
When I use product bundle the price is not showing in the translated product. |
June 29, 2020 at 10:45 am | |
June 29, 2020 at 10:50 am #6475485 | |
Paola Mendiburu Supporter
Languages: English (English ) Spanish (Español ) Italian (Italiano ) Timezone: Europe/Madrid (GMT+01:00) |
Hello, Maybe there is a compatibility issue with the problem here is with Third party elementor blocks and WPML. Could you install WooCommerce Product Bundle plugin in the following test to see if we can recreate the problem here for our compatibility team to investigate further? Also could you try to recreate the page where you find the problem. Access to the test site: user: demo pass: thP5N2aV Leave me a brief notification once the site is ready. It would also be useful if you could try to recreate the problem by creating a bundle product. Kind regards, Paola |
June 29, 2020 at 11:44 am #6476023 | |
jackyK-2 |
Hello, hope to hear good news soon 🙂 |
June 29, 2020 at 12:44 pm #6476477 | |
jackyK-2 |
could you please let us know, when we can activate divi again... we have a lot of work 🙂 |
June 29, 2020 at 6:56 pm #6479757 | |
jackyK-2 |
Hello |
June 30, 2020 at 9:20 am #6483679 | |
jackyK-2 |
Hello, |
June 30, 2020 at 11:24 am #6485459 | |
Hi, I am preparing all the content to send it to the compatibility teams. Could you tell me the steps to reproduce the problem please? I create a product but I can´t see the price even in the original product. Kind regards, Paola |
June 30, 2020 at 12:09 pm #6485781 | |
jackyK-2 |
Hello Paola, you deleted all the products i uploaded? the problem is ONLY with bundels... some are showing some not as mentioned here : i have a meeting starting now, and will be back in an hour. |
June 30, 2020 at 3:12 pm #6487979 | |
jackyK-2 |
Hello again, Hello there, Thanks for getting in touch! I can see from the Status Report you provided with your ticket that you are using WPML to add support for multiple languages in your site. Is this correct? If so, then please note that as mentioned in this FAQ: https://docs.woocommerce.com/document/bundles/bundles-faq/#section-14, Product Bundles does not support WPML directly. We know that in the past WPML developers have added an integration with Product Bundles -- taking a look at their compatibility site, it seems that the last Product Bundles version they tested was 4.13.3: hidden link. The best way to proceed with this is to bring this issue to the attention of WPML developers -- it is highly possible that the integration they have added needs updating. On a side note, although WPML is great for offering a WordPress site in multiple languages we have seen many issues with the way it works in WooCommerce stores. WooCommerce core recommends using WooCommerce Multilingual Press for adding more languages in your WooCommerce store. MultilingualPress relies on WordPress Multisite, which is the most future-proof and performant approach to offering a website in multiple languages. Since we are not the developers of this extension, we are not fully aware of the limitations it might impose on WooCommerce core functionality. For example, there is a chance that cart contents do not persist between the different languages or stock is not automatically synced. That’s why we would recommend contacting the WooCommerce Pre-Sales team first if you decide to proceed this extension! Looking forward to hearing back from you! Cheers, Maria |
July 1, 2020 at 7:24 am #6491767 | |
jackyK-2 |
Hello, any news? |
July 1, 2020 at 9:18 am #6493011 | |
Hi, I have seen the problem. The problem is that the bundled products are not copied in the translation. If you go to the translated product you click on edit product and if you go to the Bundled Products tab you will see that there is no product added that´s the reason also why is not showing the price. For the moment you can add it manually. The issue is now escalated to the compatibility team for a detailed investigation. This might take some time I will let you know once I have an update. Kind regards, Paola |
July 1, 2020 at 9:43 am #6493181 | |
jackyK-2 |
Hello Paola, thnaks for your answer.. |
July 1, 2020 at 9:48 am #6493245 | |
I will keep you update. Thanks to you! Paola |
July 2, 2020 at 2:13 pm #6505445 | |
Hi, I hope you are well. The thing is that the translation with the advanced translator editor is not working. Instead if you use the Classic Translator editor it is working fine. As a workaround you can use the Classic Translator editor for translate the products. Kind regards, Paola |
