The client is experiencing an issue where the product section layout breaks when switching the website language from English to another language, such as French. The products, which should display in a 3-column layout, are misaligned and only two products are displayed.
If you're facing a similar issue with your product layout when changing languages, we recommend the following steps:
1. Ensure you take a backup of your site for safety.
2. Update all your plugins, including Elementor Pro and WPML, to their latest versions.
3. Update your Astra theme to the latest version.
4. Open the default language home page in Edit mode and make a minor change, such as adding a space or a plus sign in the page title, then update the page. Remove the change and update the page again.
5. Send the home page for translation again from WPML >> Translation Dashboard.
6. Clear all types of cache (site/server/CDN) to see if the issue resolves.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Noman 3 months, 2 weeks ago.
Assisted by: Noman.
December 2, 2025 at 9:42 am #17625273
frederikc-7
I’m facing an issue with the product section on my website.
When the default language is set to English, all products display correctly in a 3-column layout. However, when I switch the website language (for example, to French), the product layout breaks — only two products show, and the entire section becomes misaligned.
This issue seems to be related to the language switcher affecting the product carousel/grid layout.
Could you please check and help fix this issue?
I have attached screenshots for your reference.
December 2, 2025 at 12:00 pm #17626175
Noman
Could you please follow the below steps and see if this resolves the issue:
1. Take a backup of your site first for safety reasons.
2. Update all outdated plugins to the latest version including Elementor Pro and WPML.
3. Update Astra theme to the latest version.
4. Then, please try the below procedure:
4.1. Please open the default language home page in Edit mode.
4.2. Make a small change, for example, add a space or + sign in your page title.
4.3. Update the page by pressing the “Update” button.
4.4. Now, please remove that small change that did in step #4.2.
4.5. Update the page again.
4.6. Now, please try to send the home page for translation again from WPML >> Translation Dashboard.
5. Clear all sorts of site/server/CDN cache and see if this resolves the issue.
Thank you
