If you're noticing that a product is not translating correctly, even though it appears translated in the translation dashboard and edit mode, but still displays in English on the front end in all languages.
We recommend following these steps:
1. Navigate to Products -> Product Tabs.
2. Change the language to your secondary languages.
3. Delete the translated tabs.
4. Empty the trash.
5. Go to WPML -> Settings -> Post Type Translation.
6. Set the 'woo_product_tab' as Not Translatable.
7. Edit the file .../wp-content/plugins/woocommerce-product-tabs/src/Product_Tabs.php.
8. On line 58, replace the existing code with the following workaround:
$wpt_tabs[ $key ]['title'] = esc_attr( $prd->post_title );<br />// WPML Workaround for compsupp-7241<br />if ( class_exists('Sitepress') ) {<br />    $string = $wpt_tabs[ $key ]['title'];<br />    $textdomain = 'WordPress';<br />    $string_name = 'WPML Workaround : '.substr($string, 0, 20);<br /><br />    $wpml_default_lang = apply_filters('wpml_default_language', NULL );<br />    $wpml_current_lang = apply_filters( 'wpml_current_language', NULL );<br /><br />    if ($wpml_default_lang == $wpml_current_lang ) {<br />        do_action( 'wpml_register_single_string', $textdomain, $string_name, $string );<br />    }<br />    // Apply the translation to the string<br />    $string = apply_filters('wpml_translate_single_string', $string , $textdomain, $string_name);<br /><br />    $wpt_tabs[ $key ]['title'] = $string;  // Replace the title<br />}
9. Visit the front end to register the new string.
10. Navigate to WPML > String Translation and translate the new string.
Please note that this solution might be outdated or not applicable to your case. If the issue persists, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
Last updated by Osama Mersal 1 year, 8 months ago.
Assisted by: Osama Mersal.
March 5, 2024 at 11:06 am #15373943
dawoodH
Hello, I noticed that a product is not translating even though in the translation dashboard it shows it translated correctly as well as when you view it in edit mode.
This is the link to the product: hidden link
It just shows in English in every language.
Can you support me with this? Thank you!
March 5, 2024 at 11:21 am #15374054
Osama Mersal
WPML Supporter since 02/2020
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
March 5, 2024 at 11:46 am #15374255
Osama Mersal
Thanks for the access details. Please translate the tabs. (hidden link)
Osama
March 5, 2024 at 11:55 am #15374290
dawoodH
Hello, tabs are now translated 🙂
March 5, 2024 at 12:11 pm #15374372
Osama Mersal
Thanks for translating the tabs. After translating the tabs, you need to update the products in the default language and their translations.
Kindly check this product. (hidden link)
Osama
March 5, 2024 at 12:37 pm #15374514
dawoodH
Thanks, now the descriptions are translated but the titles of the tabs are not, how can I fix that?
March 5, 2024 at 12:54 pm #15374584
Osama Mersal
It seems like a compatibility issue. Please login to this sandbox site and install the Product Tabs plugin. (hidden link)
After that, please create three test tabs and translate them to replicate the issue. Please let me know if the problem is replicable so I can check with our compatibility team.
Osama
March 5, 2024 at 1:09 pm #15374656
dawoodH
Hi, I managed to install and create 3 tabs but I can't find the option on where to translate them :/
March 5, 2024 at 1:22 pm #15374689
Osama Mersal
I've set the tabs to be translatable from WPML-> Settings-> Post Type Translation section. Please translate the tabs to replicate the issue.
Osama
March 5, 2024 at 1:27 pm #15374694
dawoodH
Hi, thanks! I translated the German version and now on the product page it displays both english and german tabs, regardless of the language selected.
March 5, 2024 at 2:22 pm #15374983
Osama Mersal
Thanks for replicating the issue. I've consulted our compatibility team, and I'll update you as soon as I get their reply.
Osama
March 5, 2024 at 2:28 pm #15375009
dawoodH
Perfect thank you so much, let me know when you have updates! 🙂
March 5, 2024 at 2:30 pm #15375013
Osama Mersal
You are more than welcome! I will keep you updated as soon as I receive any new information.
Osama
March 11, 2024 at 10:28 am #15394141
dawoodH
Hello! Any updates on this?
March 11, 2024 at 11:13 am #15394439
Osama Mersal
Our compatibility team is debugging the issue, but I'm afraid I don't have an update yet.
Thanks for your patience.
Osama
