This topic contains 17 replies, has 3 voices.
Last updated by Andrey 1 year, 8 months ago.
Assisted by: Andrey.
September 2, 2024 at 2:22 pm #16132384
Andrey
WPML Supporter since 06/2013
Does this still happen for the product when you do these extra steps?
Please indicate the product the issue happens with.
September 2, 2024 at 7:23 pm #16133423
Jānis Anspaks
Yes, these extra steps helps only once. If I make a change then again - change is not registered and I need to do these extra steps for change to be registered.
Product that has this problem: hidden link
Title: Saulrieta brauciens Jelgavā izgaismotās laivās
or in english: Sunset trip in Jelgava in illuminated boats
Unfortunately I cannot give you an FTP access. We have custom hosting solution and we dont have direct accessable code. I can send it to you or we can install some wordpress plugin for that.
I attached a screenshot of one of my previous conversations with WPML support where supporter asked only for admin login details and he could create a local copy of my site to test. But of course I don't know if it is possible to do that in this case.
P.s. I am not sure you got the login details, because after I submitted the message I got an error. If you did not get the details please send me again this message where I can provide the login details for you
September 3, 2024 at 4:01 pm #16136692
Andrey
Thank you for the information.
I have checked and tested this issue, which seems specific to this product ID.
Would it be a suitable solution for you to follow the steps below?
1. Go to Products > All Products and find the problematic product.
2. Hover over it and click on "Duplicate"
3. There appears to be no issue with a duplicated product.
Please backup your database before making any changes.
September 5, 2024 at 8:35 pm #16146840
marcisL-2
Site owner
Thank you very much! Looks like the issue could be solved by duplicating the product and deleting the old one. It appears that the issue is not present in the product duplicate.
