This topic contains 7 replies, has 1 voice.
Last updated by Andreas W. 4 months, 1 week ago.
August 7, 2025 at 1:22 pm #17302700
lucasS-30
I am trying to manage stock on my website using WPML. I expected to see the same stock levels for the same products in all languages. The issue can be seen on this page: hidden link.
The stock levels are not synced between languages. Specifically, Stock EN is 16, while Stock NL is 0.
Why is the product stock not syncing between languages?
How can I ensure that stock levels are the same for all languages?
August 7, 2025 at 1:46 pm #17302817
lucasS-30
I forced the stock on the NL product using this snippet:
* Force stock
function force_stock_for_translated_product( $translated_id, $new_stock ) {
// Get the default language (usually 'en' or 'nl')
$default_lang = apply_filters( 'wpml_default_language', null );
// Get the original product ID in default language
$original_id = apply_filters( 'wpml_object_id', $translated_id, 'product', false, $default_lang );
// If original exists, update its stock
if ( $original_id ) {
update_post_meta( $original_id, '_stock', $new_stock );
wc_delete_product_transients( $original_id );
wc_delete_product_transients( $translated_id ); // Just to be sure
} else {
// If no link found, force update on translated product directly
update_post_meta( $translated_id, '_stock', $new_stock );
force_stock_for_translated_product(38060, 16);
This works; so why is WPML not syncing the stock level?
August 7, 2025 at 2:07 pm #17302873
lucasS-30
I changed the setting _stock from `don't translate` to `copy` and now the stock synces between languages when I save the product. What is the correct setting?
August 8, 2025 at 5:45 pm #17306126
Usually, the field _stock should be set to "Not translate".
The following fields should be set to copy:
total_sales
_backorders
_downloadable
_download_expiry
_download_limit
_manage_stock
_virtual
_weight
_width
_price
_regular_price
_sale_price
_sku
_sold_individually
_stock_status
_tax_class
_tax_status
The field _purchase_note should be set to "Translate".
The following fields are by default set to "Not translate":
_wcml_average_rating
_wcml_rating_count
_wcml_review_count
_wc_average_rating
_wc_review_count
If you get an unexpected behavior using these default settings, then this might be due to custom code or a third plugin.
August 11, 2025 at 8:39 am #17308431
lucasS-30
Can you help me debug this? We are running of the shelf WooCommerce + WPML + Shoptimizer theme, no custom code.
What would be the downside of leaving it to copy, this seem to be working?
August 12, 2025 at 5:14 pm #17314417
I can only suggest using the recommended settings from my last comment. Any different setting could cause unexpected issues between WooCommerce and WPML.
August 13, 2025 at 6:42 am #17315572
lucasS-30
Sure I want to use this setting, but then the stock sync doesn't work.
So please provide some guidance and support in this matter.
August 13, 2025 at 4:19 pm #17318559
After adjusting the settings, you might need to update the translations of the products to sync the fields.
If this doesn't resolve the issue, I'd be happy to offer to take a closer look.
The required fields are located below the comments section when you log in to leave the next reply. The information you provide is private, meaning only you and I can see and access it.
IMPORTANT
I may need to install a plugin called "All In One WP Migration" to create a copy of the website so I can investigate the issue further.
However, I would also be very grateful if you could provide a staging site or a copy of the website from your server for this purpose.
If you have any questions about creating such a staging site, you can consult your hosting provider. Please note that WPML must also be registered on this staging site at https://wpml.org/account/websites/.
If you are unable to provide such a copy of the website for testing, please let me know on this ticket.
Video:
The topic ‘[Closed] Product stock is not synced between languages’ is closed to new replies.
