This topic contains 22 replies, has 2 voices.
Last updated by Bruno Kos 4 years ago.
Assisted by: Bruno Kos.
April 20, 2022 at 8:57 am #11052945
alexanderT-35
Bruno,
I do not recall adding any custom CSS in this regard. As a matter of fact nothing has ever been changed. It may be potentially caused by the constant automatic updates of WordPress and other plugins but I am not sure.
As to what you have mentioned; must say that I do not quite understand what you mean.
The WPML menu has always been that by default. It is not possible to set a "Language" parent menu item and set all other languages under it as submenu items, so I do not quite understand what you mean here. Would you be able to explain in other words?
How can this explain why it does work on android devices and does not work on iOS devices?
Alex
P.S. The mobile menu does work on desktop but does not work if it is actually being opened from a mobile device.
April 20, 2022 at 9:33 am #11053463
alexanderT-35
You are right, I never have waited long enough for the page to reboot and clicked on the German submenu item in the menu. Realized that from other pages which may take little longer to initiate. From other pages if time allows I can still tap on the language I need and it sometimes gets me to the translation but sometimes not.
Which makes your point valid, the parent item in the switcher (current langue) acts like a link to the same page to be rebooted.
Although, I did not understand where you found the alleged CSS code that might conflict with the WPML dropdown code.
April 20, 2022 at 10:37 am #11054133
alexanderT-35
If disabled then the whole menu does not work properly.
April 20, 2022 at 11:07 am #11054615
Bruno Kos
Yes, you can see how CSS and source code looks like in WPML by default - on mobile phones these are open so you can choose other languages, since the main dropdown is also a link.
Something like this may help:
#av-burger-menu-ul .wpml-ls-item ul.sub-menu {
    display: block;
As this would override this then.
.html_av-submenu-hidden #av-burger-menu-ul li ul {
    display: none;
Bruno Kos
April 21, 2022 at 9:30 am #11062955
alexanderT-35
Hi Bruno,
I did not understand your last email unfortunately. The parent menu item was never a link with WPML switcher on mobile, it would always allow a tap without redirection, now it does not though.
I also do not understand the source of the problem as to where has it come from and most importantly should I wait for an update from WPML or Enfold or try to find a different fix?
Alex
April 21, 2022 at 10:49 am #11063773
Bruno Kos
I am not sure if I can into more detail as I've already exhausted all the possible explanations, but within WPML everything works properly. So perhaps you should submit this to Enfold support - they will be able to explain about the menu thing, you can send them my answers directly.
Bruno Kos
April 21, 2022 at 11:24 am #11064083
alexanderT-35
Bruno,
I see. Thank you very much for taking a look at the issue and your time and effort.
Have a nice one 🙂
Best,
Alex
April 21, 2022 at 11:58 am #11064449
Bruno Kos
Hopefully they will have a solution for this.
Bruno Kos
