This topic contains 14 replies, has 3 voices.
Last updated by Andreas W. 1 year ago.
October 18, 2023 at 12:23 pm #14603987 | |
nikolaosM |
Hello, I have setted up a user with the role shop manager. The user has permition to translate conntent. Sometimes when he is trying to translate a product he gets redirected to the translations queue. I have setted up the product to use wpml translation editor for the translations. I would like to inform you that this problem is not always occurring and sometimes I can not regenarate it, but my client says it has happened and he has also send me screenshots. Why is this happening? Thanks! |
October 19, 2023 at 12:10 pm #14614627 | |
Mateus Getulio Supporter
Languages: English (English ) Portuguese (Brazil) (Português ) Timezone: America/Sao_Paulo (GMT-03:00) |
Hi there, Thanks for your contact. Before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process. This might be expected. Once a translator takes and completes a translation job, the same job can no longer be taken by a second translator. If you want a different translator to edit and review the same translation, you need to resend the content for translation and assign it to that translator. Kindly check our doc related: https://wpml.org/documentation/translating-your-contents/how-to-set-up-local-translators-and-language-pairs/ Please let us know if the info above helps. Thank you. Kind regards, |
October 19, 2023 at 1:40 pm #14615691 | |
nikolaosM |
I can understand that, but the translations were made by only one account/translator. Also sometimes the problem occures when the user creates a translation after he creates a product. |
October 21, 2023 at 5:21 am #14627687 | |
Andreas W. Supporter Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: America/Lima (GMT-05:00) |
Hello, I would like to assist you on this matter. Please name an example content on which the translator is currently having this issue and provide me temporary admin access (wp-admin and FTP) to the website to investigate this issue further. You can find the required fields below the comment section when you log in to leave the next reply. The information you provide is private, which means only you and I can see and access it. IMPORTANT The private response form looks like this: Next time you reply, click "I still need assistance." Video: Please note that we are obliged to request this information individually on each ticket. We may not access any access information not specifically submitted on this ticket in the private response form. Best regards |
October 24, 2023 at 4:13 pm #14649649 | |
Hallo, Um Dir hier behilflich sein zu können muss ich Zugriff als Admin-Nutzer haben. Aktuell habe ich allerdings keinen vollen Zugriff zum Backend. Kannst Du im betroffenen Nutzerkonto bitte die Rolle "Admin" festlegen und mir danach hier kurz Bescheid geben? Mit freundlichen Grüßen |
October 25, 2023 at 4:01 pm #14663073 | |
nikolaosM |
Can you responde in english please? |
October 25, 2023 at 4:58 pm #14663579 | |
Hello, My apologies, seems I got mixed up between tickets. In order to be able to help you here, I need to have access as an admin user. However, I currently don't have full access to the backend. Can you please set the role “Admin” in the affected user account and then let me know briefly here? Best regards |
October 26, 2023 at 9:53 am #14668943 | |
nikolaosM |
I will have to give you access to another account because our customers are currently using the account I have send you to add and edit products and I don't want them to have access to things that might harm the site. Please open a hidden responce so I can provide you with the admin credentials. Thanks! |
October 26, 2023 at 3:23 pm #14672141 | |
Hello, Thank you for your message. The private reply form is enabled again. Best regards |
October 27, 2023 at 11:53 pm #14682425 | |
Hello, As you can see on WPML > Translation Management > Jobs there are more than 500 jobs currently in progress. I would like to assist you on this matter, but I would really need an example of the content on which the issue occurs. Please ask the translator on which content I can currently see the issue. Further, please update our WPML Multilingual CMS Plugin to version 4.6.7: Best regards |
October 30, 2023 at 8:27 am #14688975 | |
nikolaosM |
Hello, I can see what you are talking about. The issue although is occuring in random products and sometime when translating a new added product. So I can not provide you with the specific product that this is happening. I will update the plugin and come back to you if this happens again. Thanks! |
October 30, 2023 at 3:10 pm #14693075 | |
nikolaosM |
Hello again, The WPML plugins are up to date! |
October 31, 2023 at 4:48 pm #14702563 | |
Hello, I can sadly currently not see the issue on the site, not with an existing job and neither with a new test product. I then created a new Shop Manager account, added the translator role, and tested again, but I still do not see the issue, even when testing 10 different jobs, incl. a newly created product (draft). I would really need an example. Could it be that you earlier used the Advanced Translation Editor on the site and then switched to Classic Translation Editor? I am asking, as it could be that there are still jobs active that use the Advanced Translation Editor and on the ATE Error Log I see "Unable to authenticate". This should be solved when canceling the affected jobs at WPML > Translation Management > Jobs. Best regards |
November 1, 2023 at 8:50 am #14705953 | |
nikolaosM |
Hello, Well, I can't give you an example because myself couldn't reproduce the problem. I only get to see it with screenshots, our customer provided us. Also I can not remember changing the Translation Editor from advanced to classic. It is an old site so I think we didn't change to Advanced Translation Editor ever. For the last part of your answer as you can understand I can not have a person that has very little knowledge about WPML and Woocommerce in general, full access to WPML settings. So I need an answer about why the problem is happening to give our customers a feedback. They said us that it happened recently on Chicago dark blue product. I couldn't reproduce the problem myself even on this product. Thanks! |
November 2, 2023 at 2:52 pm #14718033 | |
Hello, I can sadly not investigate the issue if it is not replicable. If the Shop Manager reports the issue again, try to open the job yourself, and then please log in with the same account and try you recreate the issue. In case the issue might only occur with the specific user account, then we can investigate further. Best regards |
