You are trying to ensure that products in a second language have a default variation selected, but despite upgrading WPML WooCommerce Multilingual to version 5.5.2.3, the issue persists.
We recommend modifying a specific file to address this issue. Please follow these steps:
1. Open the file
/wp-content/plugins/woocommerce-multilingual/classes/Synchronization/Component/Attributes.php
2. Change the following section:
$defaultTermTranslations = $defaultTerm ? $this->elementTranslations->get_element_translations( $defaultTerm->term_taxonomy_id, false, true ) : [];
to:
$defaultTermTranslations = $defaultTerm ? $this->elementTranslations->get_element_translations( $defaultTerm->term_taxonomy_id, false, false ) : [];
3. Save the original product to trigger a synchronization, which should assign the proper default attribute.
If this solution does not resolve your issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
This topic contains 22 replies, has 0 voices.
Last updated by Kor 3 months, 3 weeks ago.
October 31, 2025 at 3:47 pm #17536404
kevinB-74
I am trying to ensure that products in the second language have a default variation selected. The issue can be seen on this page: hidden link. I read a related topic here: https://wpml.org/forums/topic/products-in-second-language-dont-have-default-variation-selected/page/2/. I upgraded WPML WooCommerce Multilingual to version 5.5.2.3 but still face the issue.
Products in the second language don't have a default variation selected. Instead of seeing a default variation, none is selected on translated products.
Why are default variations not selected for products in the second language?
How can I ensure that default variations are selected for translated products?
November 3, 2025 at 10:37 am #17540306
Thanks for contacting us.
I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
November 5, 2025 at 9:27 am #17548978
Thanks for your reply. I was able to see the issue here: hidden link
Could you please let me know which option you used on the primary language product to set the default variation?
November 5, 2025 at 1:13 pm #17550352
kevinB-74
primary laguage for this is English
November 5, 2025 at 1:20 pm #17550445
Thanks for your reply. Yes, I understand. Could you please let me know which option you selected on the primary language product to set the default variation?
Here is the link for reference: hidden link
November 5, 2025 at 5:10 pm #17551355
kevinB-74
Exactly as it is on this page : hidden link
Default option is supposed to be size 5
November 6, 2025 at 12:04 pm #17553751
Thanks for your reply. I've checked, and it looks like you're using some 3rd party plugins to set up the swatches and it looks complex. Could you please install the required plugins here on our sandbox site hidden link and try to replicate the issue over there?
You can install the required plugins and theme to replicate the issue.
November 6, 2025 at 1:59 pm #17554352
kevinB-74
You sandbox website is so slow. I can't reinstall all my website on this server...
But it you want on my staging you can disable third party plugin, save again products and check if default variation is well assigned into all translated languages
November 6, 2025 at 4:15 pm #17554803
Thanks for your reply. I've tested it on our sandbox site here hidden link and I'm able to select the default attribute without issues. This is the login to our sandbox site hidden link
Looks like the issue is isolated to your Website for some reason. Could you please create an administrative account for me?
Also, I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
November 6, 2025 at 5:22 pm #17554938
Thanks for your reply. I will escalate this now to our 2nd Tier Support. I will come back to you once I've feedback.
November 14, 2025 at 8:20 am #17577664
kevinB-74
How are you? Do you have any news regarding my issue?
Regards
November 14, 2025 at 1:33 pm #17579348
Thanks for your patience. My apologies for overlooking this. I've some feedback from our 2nd Tier Support, and they mentioned that the issue could be related to corrupted WCML files. Replacing the WCML plugin files could fix it. Could you please check why your staging site is inaccessible now? hidden link
November 17, 2025 at 7:35 am #17582549
kevinB-74
Yes I had to refresh staging environment. Could you activate private mode so that I send you new admin link?
November 17, 2025 at 2:48 pm #17584565
Thanks for your reply. I've enabled the private reply option for you.
November 17, 2025 at 5:57 pm #17585750
Thanks for your reply. Could you please restore the credentials for this username "wpml-support" again? I need direct access.
Error: The username wpml-support is not registered on this site. If you are unsure of your username, try your email address instead.
