The client reported that each time they duplicated a single product to another language for manual translation, all product reviews were deleted.
We recommended two workarounds:
1. Navigate to WooCommerce > WooCommerce Multilingual & Multicurrency > Settings and disable the option "By default, show reviews in all languages".
2. Alternatively, edit the file
wp-content/plugins/woocommerce-multilingual/inc/class-wcml-comments.php
. Around line 209, replace the code
if ( $this->is_reviews_in_all_languages( $obj->query_vars['post_id'] ) ) {
with the following code
if ( $this->is_reviews_in_all_languages( $obj->query_vars['post_id'] ) && !isset( $_REQUEST["action"] ) ) {
We emphasized the importance of backing up the database and website before making any changes.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket.
This topic contains 8 replies, has 3 voices.
Last updated by Long Nguyen 1 year, 8 months ago.
Assisted by: Long Nguyen.
March 5, 2024 at 4:18 pm #15375508
sebastiaanV-11
Each time I duplicate our single product to another language (to translate manually with ChatGPT), all product reviews are deleted.
Each time I add a new language to the shop, I duplicate the product we have (just one) for manual translation. But each time I duplicate it all product reviews are deleted from the product and I need to back up the WP_comments and commentmeta tables to restore them.
March 5, 2024 at 5:07 pm #15375792
Mateus Getulio
Before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
We would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
March 5, 2024 at 5:07 pm #15375793
sebastiaanV-11
I was just about to share login information and then Mateus just randomly changed this into a ticket. Very weird.
March 5, 2024 at 5:09 pm #15375794
sebastiaanV-11
I cannot share credentials. Please reactive it. Thanks.
March 5, 2024 at 5:11 pm #15375797
Mateus Getulio
Please check if the fields are visible now.
Thank you, please let us know.
March 7, 2024 at 6:42 am #15382318
Long Nguyen
WPML Supporter since 02/2022
After trying some troubleshooting steps on your site, I see the issue persists. I will take a backup of your site, restore it on my local host and investigate the issue further.
March 8, 2024 at 3:36 am #15387250
Long Nguyen
I got some information from our 2nd tier support: there are two workarounds to fix the issue on your site:
1. Go to WooCommerce > WooCommerce Multilingual & Multicurrency > Settings > Disable option " By default, show reviews in all languages".
2. Or edit the file wp-content/plugins/woocommerce-multilingual/inc/class-wcml-comments.php. Around line 209, replace the code
with this one
March 15, 2024 at 1:24 pm #15414613
sebastiaanV-11
I have updated the PHP file and will test this once we're adding a new language. Thank you
March 18, 2024 at 1:47 am #15419040
Long Nguyen
Let me know if you have any questions.
