The client is experiencing issues with translated 'account' pages showing as blank and Elementor templates and JetFormBuilder forms not displaying in French on their website.
1. Ensure that JetEngine Profile Builder pages are set as Translatable in WPML → Settings under the Post Types Translation section.
2. Verify that each account page has a French translation by checking under the French flag in Pages. Edit and update the French version if necessary.
3. If the navigation menu is missing or blank in French, go to Appearance → Menus, select the French menu, and ensure all relevant profile/account pages are added and published in French.
4. Use WPML → String Translation to translate any static or dynamic text, such as menu labels or JetEngine-generated elements.
5. Set Elementor templates and JetFormBuilder forms to Translatable under Post Types Translation in WPML → Settings. Check for French translations in Templates → Saved Templates and JetFormBuilder → Forms, and add or review the translation as needed.
6. Use the Advanced Translation Editor to verify and publish the translation.
7. Clear any site or browser cache if the preview still does not show the template in French.
8. If issues persist, consider switching to the parent theme temporarily to rule out issues with child theme customizations.
If after following these steps the issues persist, or if you encounter any error messages or blank content, it might be necessary to consult further with our support team. We recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem continues, please open a new support ticket at WPML support forum for personalized assistance.
Last updated by Kim 7 months, 1 week ago.
October 2, 2025 at 9:33 pm #17453103
Kim
I am trying to translate the 'account' pages built with Jet Engine's Profile Builder, which are only visible to logged-in users. The issue can be seen on this page: hidden link.
I expected to see the top navigation menu with all the user pages translated into French, including 'Saved Jobs', 'Applicant Submissions', 'Post a Job', 'Saved Candidates', 'Find Resumes', 'Candidate Verification', 'Sourcing Request', 'Turnkey Recruitment', 'Settings', and 'Support'. Instead, I got a blank page, even though the content was translated. Additionally, Elementor templates and JetFormBuilder forms are not showing in French if I preview the template.
Why are the translated 'account' pages showing as blank?
Why are Elementor templates and JetFormBuilder forms not displaying in French?
October 3, 2025 at 1:41 am #17453236
Thanks for your reply. I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
October 3, 2025 at 4:23 pm #17455051
Thanks for your reply. I've checked, and it looks correct as shown in the attached screenshot when I checked this page hidden link
October 6, 2025 at 4:34 pm #17461533
Kim
Thank You Kor,
I have another issue with this page, each section has a "pen" button so users can edit their fields, each of these buttons trigger a Jetformbuilder (which is already translated) I selected the french version of the form by editing the french page template with Elementor, but when i test the front end, it shows the english version.
When I try to edit the buttons in the french version of the profile page (hidden link) the dropdown only whos in english, although I already translated the popup I am searching for to french.
Even by doing this, it should be done automatically, I should not have to translate popups and then link them manually one by one, I have over 29 per language, is going to take me forever, it should be done automatically. I had to switch to wordpress editor because i though it was the only option but I feel this should be handled by the plugin.
I would appreciate your help on this.
https://wpml.org/forums/topic/profile-builder-popup-cannot-be-translated-automatically/
October 6, 2025 at 8:31 pm #17462007
Kim
To give more context: the forms are inside a popup that’s also translated, and it correctly displays the French version of the form. So, I had to work on two layers to make it function properly — translating the form itself, and then translating the popup by manually adding the French form inside it.
After that, I tried what I mentioned earlier — editing the “pen” button — but the language options are glitching and don’t appear on the front end.
October 7, 2025 at 5:27 pm #17465066
It looks like you're referring to another issue. Our support policy allows us to take care of only one issue per ticket.
Continuing with one issue per ticket helps not only supporters to focus on one issue at once, but also enables other users to find solutions to their questions faster.
So, I've split your new issue here https://wpml.org/forums/topic/profile-builder-popup-cannot-be-translated-automatically/ so that we can follow up regarding the popup form not updating to the correct form.
As for this ticket, are you still having issues with "translated 'account' pages showing as blank" and "Elementor templates and JetFormBuilder forms not displaying in French"?
October 7, 2025 at 9:42 pm #17465481
Kim
Thank you Kor! No problem, I appreciate your help!
