The client is experiencing issues where posts are not appearing in search results in the secondary language when using Elementor+Pro and WPML main plugin, even after switching to a default theme and disabling other plugins.
We recommend updating all WPML plugins to the latest versions as the client might be using outdated versions. Here are the steps to potentially resolve the issue:
1. Take a post that does not appear in search results in the secondary language.
2. Make a small change to the post in the original language.
3. Update the post.
4. Open the translation (it should now require an update) and complete it.
5. Test again by searching for that post.
If this solution does not resolve the issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by 2 weeks, 3 days ago.
Assisted by: Andrey.
