If you're experiencing issues where the translated version of your page does not match the front-end display, showing an old template homepage with outdated themes and texts, despite correct strings in both Italian and English in the editor.
We recommend duplicating the page from the primary language and translating it again. After this, edit the translated version with your page builder and save it. This approach resolved similar issues related to icons and styling. Additionally, ensure that your WordPress memory is sufficient, as insufficient memory can prevent page options from being saved correctly in translations. You can check and address WordPress memory issues here: WordPress Memory Issue.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket with us for further assistance.
Last updated by Kor 1 year, 7 months ago.
August 29, 2024 at 9:27 am #16118914
edoardoA-4
Solve the ticket (I don't know why is marked as "solved" without my feedback) on date August12, 2024 a 9:38 am, with your operator Carlos Rojas.
I follow the instruction but the problem persists. If I can't solve it, I have to request the refund.
when I duplicate a page in english, the pages on the frontend are shown with the old, deleted template
To solve the bug.
August 30, 2024 at 8:19 am #16123599
edoardoA-4
no answers after 24hrs?
August 30, 2024 at 11:35 am #16124509
Thanks for reaching us and I apologize for the delay in response.
September 2, 2024 at 10:12 am #16130948
Thanks for your reply.
To clarify, are you saying you'd like to duplicate your English language homepage here hidden link to Italian Language here hidden link ?
September 2, 2024 at 10:30 am #16131035
edoardoA-4
It's not so.
The original language is italian and I want the same page in english.
On your editor, all the strings are correct, both italian and english, but on the front-end there's no matching and I see the old template homepage (!), with old theme (nowadays deleted from wy WP) and old texts.
September 2, 2024 at 1:42 pm #16132099
I see the issue now. It looks like this domain hidden link is using a different WordPress installation. Even after deactivating the WPML plugin here hidden link , the domain hidden link is still loading.
Please check with your hosting provider to see if you have a different WordPress installation.
September 5, 2024 at 7:47 am #16143386
edoardoA-4
Thanks, finally my customer show me the website's file manager. Effectively, there was a WordPress setup on the /en folder...no one told me that the old website was built in this way. Thank you.
Now I see the translate page (cbox.cloud/en) but I miss a lot of style, why?
September 5, 2024 at 9:08 am #16143751
I compared both pages hidden link and hidden link and I noticed that both page layouts are the same but the icons show different sizes. Could you try replacing the icons and retranslating the page again?
September 5, 2024 at 11:43 am #16144603
edoardoA-4
unfortunately the errors are many. Here's some screenshots
September 5, 2024 at 5:09 pm #16146182
Thanks for your patience.
Please could you check now? hidden link
September 9, 2024 at 7:40 am #16154216
edoardoA-4
Thanks, it seems ok. Shall I know how you did it? In order to not repeat the same issue in the future. Thanks!
September 9, 2024 at 8:18 am #16154340
Thank you for your response.
I duplicated the page from the primary language page and translated it again. Then I edited the translated version with the page builder and saved it again. This resolved the issue with the icons and styling.
It appears that the problem with the translated page options not being saved was due to insufficient WordPress memory, as indicated here: hidden link . Once this issue is addressed, your future translations should function correctly.
September 9, 2024 at 9:02 am #16154632
edoardoA-4
Thank you very much, your job has been useful and successful. Regards
