The product numbers displayed through the category widgets on the website are displayed incorrectly in the 2nd Language.
For example, this page hidden link is in the native language of the site and the number 7 is displayed correctly on the page and in the menu on the left.
When you view the same category in English at hidden link , 7 products have been published, but the number of products is shown as 9 in the widgets menu on the left.
We tried every procedure suggested for a solution in the forum, fix term count etc. But there was no change. We do not know where he gets this number from, all product translations progressed synchronously, but in some categories in the 2nd language, these numbers are displayed as an excessive number of products. Doesn't match the number of products published?
How can we solve this problem and ensure synchronous progress?
I understand the issue you're having and will try my best to assist you in this matter.
Are there any products under the "Biblo"(English) category saved in Draft? If so, the Filter functionality might be trying to show the total number of products per category within the filter, including those in the draft.
Since the Filter is part of the theme, it would be better if you could reach out to the theme author or support and discuss this matter with them. It is possible that they are aware of such cases and help you better in this matter.
However, if there aren't any products saved as drafts, try synchronizing the categories to see if it resolves the issue. Please follow the steps below.
- Please go to the "WooCommerce > WooCommerce Multilingual > Categories" Tab.
- Scroll down and you'll see a button to Synchronize categories for the products. Click on that button and wait till the process gets completed.
I hope it will help. Feel free to let me know if you need further assistance in this matter. I will be happy to help.
There are no draft products except 7 products published under the English Trinket category. Likewise, there is no product in Turkish as a draft product. It already shows the numbers correctly in Turkish listings.
The problem is with the English department. It shows the wrong number as 9 when listing the products in the admin panel. But when you select the category, it lists 7 products.
We talked to the theme team, they said there was no problem with the theme. That's why we contacted you, and they told us that the problem was related to second language synchronization.
On the "WooCommerce > WooCommerce Multilingual > Categories" Tab the is now Synchronize categories for the products button. There second tab is Hierarchy Synchronization and here The taxonomy hierarchy is already synchronized. He is writing.
The problem of displaying the number of incorrect products is not only present in categories, but also in some qualification headings in the 2nd language. He has somehow created separate values for the 2nd language and it shows different numbers than the number of products installed in the system.
hidden link Although 7 products are available in this link, the menu on the left shows the number of 9 products.
The same problem exists, for example, in the designer name and other attribute titles; For example, there are 2 products in this link, but it shows 3 in English: hidden link
The problem is entirely related to the fact that numerical values are processed differently in English. Where does the system get these numbers from? How can we count the products again and get these numbers corrected?
If you have already tried to synchronize the categories and the issue persists, a closer inspection will be required to understand the root cause of the issue.
IMPORTANT
-If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box. The private box looks like this: hidden link
Best Regards,
Prosenjit
The topic ‘[Closed] Second language category filters number of products does not match number of pub’ is closed to new replies.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
