The client is trying to copy an existing product, modify it, schedule it, and then change the content of the translation as well. However, the secondary language product remains a draft instead of being scheduled to the same time as the original language.
We recommend the following steps to ensure both the original and translated products are scheduled correctly:
1. Make a copy of the product.
2. Edit and publish the original language copied product.
3. Schedule the publication date for the original language copied product. Note that the product will not be visible yet since it's scheduled.
4. Edit and save the translation of the copied product. This should keep the same publication date as the original language copied product.
We have tested this workflow successfully. If you're experiencing this issue, we suggest trying these steps.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum.
Last updated by gaborR-4 4 months, 2 weeks ago.
Assisted by: Otto.
November 26, 2025 at 11:42 pm #17613586
gaborR-4
I'm trying to copy an existing product, modify it, schedule it, and then change the content of the translation as well.
The secondary language product stays a draft instead of being scheduled to the same time as the original language.
Why does the secondary language product remain a draft when I schedule the original language product? How can I make sure, that the secondary language product will go public when the primary language product does?
November 27, 2025 at 4:06 pm #17615850
Otto
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue.
It would be better to a testing site where the issue is replicated.
Maybe I'll need to replicate your site locally. For this, I'll need to temporarily install a plugin called “Duplicator” or "All in One WP Migration" on your site.
This will allow me to create a copy of your site and your content.
Once the problem is resolved I will delete the local site.
**IMPORTANT**
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields.
Best Regards,
Otto
December 1, 2025 at 12:55 pm #17622601
Otto
Hello Ben,
The server credentials worked, but the site credentials didn't:
HIBA: A megadott felhasználónév vagy jelszó helytelen. Elfelejtette jelszavát?
Can you please check them?
Best Regards,
Otto
December 1, 2025 at 6:24 pm #17623736
Otto
I suggest the following flow:
- Make a copy of the product
- Publish it (edit it if needed)
- Schedule it for later
- Edit the translation
Following this flow worked for me. Is it a suitable solution for you?
Best Regards,
Otto
December 1, 2025 at 8:43 pm #17623938
gaborR-4
Actually, when the client wants to come out with a new line of products (basically every second Thursday at 6PM), they want them to become available at the same time in both languages, so editing the products for the secondary languages after they become public doesn't really work. Do you have any other solutions?
Ben
December 1, 2025 at 9:36 pm #17624080
Otto
Hi Ben,
Sorry, I wasn't clear enough.
- Edit and publish the original language copied product
- Schedule it for later the original language copied product. The original language copied product is not visible yet, since it's scheduled.
- Edit and save the translation of the copied product. It keeps the same publication date as the original language copied product.
I tried this workflow in this test site (you'll be automatically logged in):
Can you please give it a try there?
As far as I can see, you'll end up with the original language copied product and the translated copied product scheduled for the same date.
Best Regards,
Otto
December 10, 2025 at 4:02 am #17649842
gaborR-4
Hi Otto,
I'll try this tomorrow, thank you for your patience.
Ben
December 10, 2025 at 12:08 pm #17652097
Otto
Hello Ben,
Thanks for the heads-up. Let me know how it goes, please.
Best Regards,
Otto
December 14, 2025 at 5:58 am #17661867
gaborR-4
Hi Otto,
Here is a video of the workflow you described NOT WORKING.
As you can see, even after saving the copied product as scheduled, the secondary language copy stays as draft.
Ben
December 15, 2025 at 5:41 pm #17665538
Otto
Hello Ben,
Sorry I wasn't clear enough. You need to publish the original language copy before schedule its publication date.
Please take a look at this screencast:
Let me know if this is a suitable workflow for your use case, please.
Best Regards,
Otto
December 23, 2025 at 9:01 pm #17685631
gaborR-4
Hi Otto,
This way it seems to work.
I duplicated a product (with an existing translation), published it on the original language, then scheduled it, then went to modify the translation, and both instances were scheduled.
Thank you!
