This topic contains 15 replies, has 1 voice.
Last updated by Otto 5 months, 2 weeks ago.
Assisted by: Otto.
| Author | Posts |
| November 12, 2025 at 6:17 pm #17572220 | |
youssefT-3 |
| November 12, 2025 at 6:57 pm #17572658 | |
| youssefT-3 |
We have already tried everything. We’ve been working on this for a long time, but we can’t solve it ourselves anymore — it’s clearly something that needs WPML’s technical attention. After translating everything, several issues remain: 1️⃣ Only the Dutch version looks correct. The layout for all other languages (English, Spanish, French, German, Italian, etc.) is broken. In Dutch, all categories and subcategories are perfectly aligned and organized, but in every other language, the same sections turn into separate blocks with different spacing and alignment. The design completely breaks, even though the translations are correct. 2️⃣ The “My Account” page still doesn’t translate properly into Dutch and Spanish. It stays in English, while other pages are correctly translated. 3️⃣ The Dutch “Categories” page still shows English buttons like “Add to Cart” and “Add to Wishlist”, while other pages such as “New Products” display the correct Dutch translations (“Toevoegen aan winkelwagen”, etc.). 4️⃣ I had to manually translate all subcategories, even though I paid for automatic translation. WPML did not recognize many strings, so I had to do all of it myself. 5️⃣ After the translations were applied, the layout broke unexpectedly. I didn’t change any design or CSS — it happened automatically after WPML updated the translations. We’ve already used every WPML tool (String Translation, Utilities, Tracking, etc.), but these problems keep returning. Help us make sure that all languages (English, Spanish, French, German, Italian, etc.) keep the same layout and design as the Dutch version, New threads created by Otto and linked to this one are listed below: https://wpml.org/forums/topic/account-page-not-translated/ https://wpml.org/forums/topic/buttons-in-category-pages-are-not-translated/ |
| November 13, 2025 at 2:50 pm #17575535 | |
Otto |
Hello, I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. The information you will enter is private which means only you and I can see and have access to it. **IMPORTANT** Best Regards, |
| November 13, 2025 at 7:07 pm #17576608 | |
Otto |
Hello, Thanks. Before moving forward, can you please update Elementor, Elementor Pro and the theme Hello Biz to their latest versions? ❌ Please make a full website backup before proceeding ❌ Best Regards, |
| November 13, 2025 at 9:37 pm #17576807 | |
youssefT-3 |
Hi Otto, All updates have been completed successfully: Elementor, Elementor Pro, and the Hello Biz theme are now on their latest versions. Thanks! |
| November 14, 2025 at 2:41 pm #17579603 | |
Otto |
Hello, I am taking a copy of the site to take a better look. Meanwhile, I created separated tickets for each issue. In our experience this is better as it keeps the conversation flow more clear. Here are the new tickets: I'll reply here about the first issue (layout problem) and on each ticket separately for each issue. You should get a notification once I reply on each ticket. I'll get back to you as soon as possible. Thanks! Best Regards, |
| November 14, 2025 at 3:25 pm #17579753 | |
Otto |
Hello, The problem seems to be that some category containers use one column and some use two columns. I couldn't find where the number of columns of the category containers are set. They seem to come from this shortcode: gv_subcats, but I can't find it anywhere in the site's codebase. Can you please let me know if there is a setting to define how many columns the subcategory container will have and where? On the other hand, I noted that the front pages consists of a huge and highly customized HTML block. Can you please elaborate a bit on it? What it does and how it works? Best Regards, |
| November 14, 2025 at 4:01 pm #17579825 | |
youssefT-3 |
Hello Otto, Thanks for your reply. I want to clarify the issue so you fully understand what is going wrong. 🔵 1. The translations are correct — the LAYOUT is broken The Dutch version of the homepage is perfect. In the Dutch version, the first six subcategory blocks are displayed in one single vertical column, perfectly centered and nicely aligned (like buttons under each other). Example (Dutch layout – correct): Category title Subcategory Subcategory Subcategory … (all in one column) This layout is exactly how I want it. 🔵 2. In the other languages, WPML breaks the layout In English, French, German, Spanish and Italian: The first six items are NOT shown in one column Instead, WPML splits them into two columns / grid blocks This destroys the layout and design This is 100% a layout issue, NOT a translation issue. 🔵 3. The layout comes from a custom shortcode generated by Code Snippets The structure of these category blocks is created using a custom shortcode: ➡️ Shortcode: gv_subcats The shortcode controls the layout (1 column vs 2 columns). In Dutch, the shortcode output is correct. 🔵 4. What I need from you Please check: Why WPML renders the shortcode output differently per language Why the layout changes from 1 column (correct) to 2 columns (incorrect) How to force WPML to output the shortcode EXACTLY the same as in Dutch I only want the layout in all languages to match the Dutch version. 🔵 5. Important visual example Dutch = ❗ Correct layout (single centered column) I added screenshots above showing the difference. Best regards, |
| November 14, 2025 at 7:47 pm #17580162 | |
Otto |
Hello, Thanks. Yes, I agree, the problem is with the layout. What I am looking for is why WPML "translates" it and then breaks it. Is this the shortcode you are talking about: It does not output any HTML related to the number of columns. When inspected the HTML I see, some category containers with: Even in the same language 🤔 (i.e. English). Where are those classes coming from? They are not added by the shortcode, as far as I can see. Best Regards, |
| November 14, 2025 at 8:18 pm #17580171 | |
youssefT-3 |
Hello Otto, Thanks for your reply. I’ll clarify the issue as clearly as possible, because the problem is not coming from the shortcode itself — it is coming from how WPML processes the shortcode output. 1️⃣ The shortcode always outputs the same HTML in every language In Dutch the layout is perfect: all subcategories are aligned all sections use the same number of columns no irregular classes appear 2️⃣ ONLY after WPML automatic translation, the HTML structure is modified WPML changes the shortcode output by injecting different classes, for example: subcategories-list cols-2 rows-3 subcategories-list cols-1 rows-3 These classes do not exist in my shortcode and they are not created by my code. This proves that WPML is changing the HTML structure during the translation process, which causes the layout to break in English, Spanish, French, German, Italian, etc. 3️⃣ Manual English version looks perfect — WPML version breaks When I manually create the content, the layout is correct. So the shortcode is not the problem. 4️⃣ This is why only the Dutch version displays correctly Dutch displays the direct shortcode output → perfect. 5️⃣ We have already tried all WPML tools (String Translation, Utilities, Sync, etc.) Nothing solves the issue. ✔️ What we need from WPML Please help us find out why WPML is injecting different classes into the shortcode output, causing the layout to break in all translated languages. All three issues are important and we have been trying to solve them for two weeks without success. We paid for automatic translation and the layout breaking is not something we can fix on our side. We appreciate your help in resolving this properly. Best regards, |
| November 14, 2025 at 8:23 pm #17580218 | |
youssefT-3 |
Hello Otto, One more detail that makes the issue 100% clear: 👉 Please compare these two sections on the English page: 1️⃣ “Baby” section → manually translated by me 2️⃣ “Food & Drinks” section → automatically translated by WPML Nothing in the shortcode changes. This proves clearly: ✔️ Manual translation keeps the shortcode layout correct So the shortcode is not generating different HTML. If you inspect the HTML for “Baby”, it matches the Dutch layout perfectly. This difference between manual vs automatic translation is the key. We need WPML to stop injecting extra classes or modifying the structure of the shortcode output. Thanks again for your help. Best regards, |
| November 14, 2025 at 8:35 pm #17580246 | |
Otto |
Hello Youssef, Thank you very much for taking the time to explain the issue in such detail. In order to investigate why and where WPML is mixing things up in the secondary language, I need to understand where HTML is coming from in the original language. I've checked the code of this shortcode (in the snippets section): and it does not seem to be the source of the classes. Is it the right shortcode? If it is, I don't see the classes there. You mentioned that
Where and how it does that? Best Regards, |
| November 14, 2025 at 9:17 pm #17580279 | |
youssefT-3 |
Hello Otto, Thanks for your message. Before we continue with the shortcode/layout investigation, we kindly ask you to help us solve the two other issues, because they are more urgent for the live website: 1️⃣ Account page is not translated in Dutch and Spanish Even though everything is fully translated in WPML → We already tried: String Translation Automatic translation Scan for strings Sync tools WPML troubleshooting tools Nothing fixes it. So the Account page in: /nl/account stays English /es/mi-cuenta also stays English We need your help to fix this, because the site is multilingual and the Account page must respect the selected language. 2️⃣ Buttons inside the Dutch shop/category pages are not translated On the Dutch version of the shop and category pages, the buttons still show English text (“Add to cart”, “Add to wishlist”), even though the translations exist. The issue is ONLY in Dutch. This is something we cannot solve ourselves; we already tried every WPML tool. 3️⃣ Shortcode/layout issue We saw your reply and your questions. For now, the account translation issue and the Dutch button translations are more critical for the live website. Thank you for your help. Best regards, |
| November 14, 2025 at 11:43 pm #17580357 | |
youssefT-3 |
Hello Otto, Thank you. Before we continue, I want to clearly explain the remaining issues, because the layout problem is now fully fixed on our side. At this moment two issues remain, and both are caused inside WPML — not in our theme, not in our shortcode, not in WooCommerce. 1️⃣ “Account” page does NOT translate in Dutch and Spanish Even when Dutch is selected, the entire Account page stays in English. Examples: “Dashboard”, “Orders”, “Addresses”, “Account details”, etc. all stay in English In Spanish, the page also remains fully English Other languages work normally We already: Nothing fixes it. We need help finding why these two languages ignore their translations only on the Account page. 2️⃣ WooCommerce shop pages are not translated in Dutch When visiting the shop through categories (not through the main menu), many WooCommerce strings stay in English. Examples (see screenshots): “Home / Shop” “Showing 1–12 of…” “Default sorting” “Add to cart” “Add to wishlist” “Reviews”, “In stock”, etc. Checkout also shows English (“Contact information”, “Shipping address”, etc.) But the same strings are correctly translated when navigating through the main Dutch menu. So this only happens when entering the shop through translated category pages. This is clearly a WPML issue with WooCommerce endpoints or URL filtering. We need help understanding why these WooCommerce strings stay English when the user enters the shop from a category. IMPORTANT: The shortcode problem is solved. We only need help with: ✔ Account page not translating (Dutch & Spanish) These issues have been happening for two weeks and we cannot fix them ourselves. Thank you very much for helping us solve these remaining translation problems. Best regards, |
| November 17, 2025 at 12:32 am #17582217 | |
youssefT-3 |
Hello Otto, Just a quick update to keep the ticket active. I am still waiting for your feedback on the Account page translation issue and the Dutch button translation issue. Both issues are still happening on the live site. Please continue the investigation when possible. Thank you! |
