Last updated by Bruno Kos 6 months, 3 weeks ago.
Assisted by: Bruno Kos.
February 6, 2025 at 1:46 pm #16675799
svenH-12
I am experiencing issues with Spectra Blocks after translating my main page on livetube.tv using WPML. After a recent rebuild, the translation process reports a failure, but the frontend of the translated pages appears fine. However, in the backend, I see Block Recovery notices for some uagb/image and uagb/buttons-child blocks. I have tried recreating image duplication, deleting code from all language pages, starting automatic translation anew, and clearing caches. I suspect the Alt Text Meta might be the issue, as Spectra blocks may have a character limit for certain fields in images. I deleted such information in the media library, deleted the image blocks, and re-created them, which fixed the issue in English but not in the translations.
Block Recovery notices for uagb/image and uagb/buttons-child blocks in the backend of translated pages.
What information do you need to look into this issue together?
February 6, 2025 at 2:22 pm #16675979
Bruno Kos
Can you reproduce this issue with these blocks here?
I suppose you would see the broken block message only if you check the translation in WordPress directly?
I did not quite understand it so far so any information is appreciated.
February 10, 2025 at 12:43 am #16684876
svenH-12
Still waiting for a response
February 10, 2025 at 1:48 pm #16687403
Bruno Kos
Have you not seen my previous response in this ticket?
So this one, just above your answer:
https://wpml.org/forums/topic/spectra-blocks-problems-after-translation/#post-16675979
The topic ‘[Closed] Spectra Blocks problems after translation’ is closed to new replies.
