If you're experiencing issues with the Real 3D Flip Book plugin showing English images instead of French on the French site, it might be due to the way translations are handled.
Firstly, you should translate the FlipBooks using the WordPress Editor, as detailed here: Using different translation editors for different pages.
Ensure that the translated Flipbook is correctly set in the Elementor Widget options for the Flipbook. Each Flipbook has a unique shortcode in each language, which should be correctly assigned in the widget settings.
The author of the Real 3D FlipBook Plugin is informed and will work on a solution. For developers, adjustments can be made in the plugin files to ensure proper translation handling. In the file
\wp-content\plugins\real3d-flipbook-elementor-addon\widgets\real3d-flipbook.php
, modify the code as follows:
On line 308, replace:
$book_id = $settings['real3d_flipbook_id'];
with:
$book_id = isset($settings['real3d_flipbook_id']) ? $settings['real3d_flipbook_id'] : '';
// WPML-aware: try to resolve a translated flipbook ID (fallback to post mapping)
if ( ! empty( $book_id ) && ( class_exists('SitePress')) ) {
$translated_id = apply_filters( 'wpml_object_id', (int) $book_id, 'real3dflipbook', true );
if ( empty( $translated_id ) ) {
$translated_id = apply_filters( 'wpml_object_id', (int) $book_id, 'post', true );
if ( ! empty( $translated_id ) ) {
$book_id = $translated_id;
}And on line 311, replace:
$book_lightboxthumbnail = !empty($settings['real3d_flipbook_lightboxthumbnail']['url']) ? $settings['real3d_flipbook_lightboxthumbnail']['url'] : '';
with:
$book_lightboxthumbnail = '';
if ( ! empty( $settings['real3d_flipbook_lightboxthumbnail'] ) ) {
$thumb = $settings['real3d_flipbook_lightboxthumbnail'];
// Prefer attachment ID if available (Elementor provides ['id'] and ['url'])
if ( ! empty( $thumb['id'] ) ) {
$attachment_id = (int) $thumb['id'];
// Use WPML to get translated attachment ID if available
if ( class_exists('SitePress')) {
$translated_id = apply_filters( 'wpml_object_id', $attachment_id, 'attachment', true );
} else {
$translated_id = $attachment_id;
// If we have a translated ID, get its URL
$translated_url = wp_get_attachment_url( $translated_id );
if ( $translated_url ) {
$book_lightboxthumbnail = $translated_url;
// Fallback to the raw URL provided by Elementor if no attachment URL resolved
if ( empty( $book_lightboxthumbnail ) && ! empty( $thumb['url'] ) ) {
$book_lightboxthumbnail = $thumb['url'];
}If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
This topic is split from https://wpml.org/forums/topic/what-is-the-status-of-my-support-request-i-dont-see-anything/
This topic contains 32 replies, has 0 voices.
Last updated by 6 months, 2 weeks ago.
