The client was experiencing issues with ACF fields not being translated in their products, displayed in white boxes within an Elementor Loop Grid. In the English version, these fields appeared as empty spaces. Additionally, the links within these fields did not translate correctly and targeted the original language URLs instead of the translated ones.
We advised the client to set the 'acf_field_group' CPT to 'Not translated' in WPML > Settings > Post Types Translation, as having it set to 'translated' is not recommended. This change required re-translating the products where the ACF fields were missing.
For the links in the Elementor template, we identified a bug where the 'URL' field set to 'copy' by default was not being automatically converted.
As a temporary workaround, we suggested switching the field group to the 'Expert' mode and setting the 'URL' field translation preference to 'Translate'.
After updating the original post, the 'URL' field will appear in the translation job, allowing to manually convert the URL.
This topic contains 20 replies, has 0 voices.
Last updated by olafsO 1 month, 3 weeks ago.
Assisted by: Pierre Sylvestre.
March 11, 2026 at 11:53 am #17888434
Pierre Sylvestre
Languages: English (English ) French (Français ) Portuguese (Brazil) (Português )
Concerning the banner link, I see 2 problems:
1. It seems the category archive link it not automatically converted on your site. I will add this information to the dev ticket I already escalated.
2. It seems Elementor does not yet support the "Link" field (see hidden link).
So, the best workaround I can suggest now is the second one:
In "Baneri" ACF field group:
- Revert the "Link" field to the "URL" type.
- Switch to the "Expert" mode and set the "URL" field translation preference to "Translate".
In your "Baneri" posts, re-save the original and edit the translation job to manually convert the product category link.
Make sure to also adjust your hidden link.
Let me know if this helps.
March 11, 2026 at 2:25 pm #17889221
olafsO
Man. This:
"Switch to the "Expert" mode and set the "URL" field translation preference to "Translate"."
Where? What? 🙂
March 11, 2026 at 2:57 pm #17889345
olafsO
Found it.
Put to expert.
Clicked "Translate".
Went to Dashboard and re-translated the Banners template.
Links are still without "/en/" ;/
What do I missing?
March 11, 2026 at 3:12 pm #17889400
Pierre Sylvestre
@olafsO, as I explained, the URLs are not automatically converted (that's a bug we'll investigate).
For now, I suggest that you manually convert the URLs in the translation job.
March 11, 2026 at 5:13 pm #17890035
olafsO
Apparently I needed fresh air, as now I understood, that I need to go into actual post, not dashboard. dooh. All fixed, thank you!
March 11, 2026 at 5:52 pm #17890119
Pierre Sylvestre
Great to hear it's fixed @olafsO!
You can mark the ticket as "Resolved" to confirm.
March 11, 2026 at 6:09 pm #17890144
olafsO
Thank you \m/
