The client was able to translate a page list from Albanian to English, but encountered issues with certain fields not translating correctly, specifically numeric fields. Additionally, when switching to English, some text did not translate as expected.
We recommended the following steps to ensure proper translation of numeric fields:
1. Navigate to WPML > Settings > Custom Fields Translations;
2. Click on Show System Fields;
3. Search for all the missing fields and set them to Copy. Then, save the changes;
4. Update the original template and save. Afterwards, update its translation;
5. Update the original listing and save. Then, update its translation.
These steps should resolve the issue with fields not translating correctly. If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket.
This topic contains 11 replies, has 0 voices.
Last updated by Lucas Vidal de Andrade 1 year ago.
March 28, 2025 at 3:10 pm #16873554
freelancerI
Hello Lucas,
Thanks for your support
I achieved to translate page listimet form Albanian to English but now i have some small issues translate.
But I attached also screenshot when user switch to english lanauge doesn't make sense to have text "Cmim shume i mire"
I attached link below for the video to be more clearly.
March 28, 2025 at 3:19 pm #16873581
WPML Supporter since 11/2023
Thank you for sharing the details. I was able to verify that this issue is not coming from conflicts or from a WPML bug. Even though the labels are translated, it seems that your theme is not pulling the label in the correct language (it returns Albanian values, when they should be in English).
In this case, please reach out to your theme developer and explain the situation. It seems there's nothing we can do on our side to solve this problem. Let me know what the theme author says.
March 28, 2025 at 6:47 pm #16874382
freelancerI
Hello Lucas,
Ok thanks I report at theme Autor:
I have another question:
For the page hidden link
I want that when when user selected Albanian lanauge all the text in the right side to be according with lanauge selected as in the screenshoot:
I tried to register widget at WPML->Setting->Custom XML Configuration but did not display editable fields.
I can not trasnlate like "hourse", "weeks", "month" in Albaniane
After that i tried to looking for each field in the WPML->Setting-String translation
For more detail I atatched link of the vide.
March 31, 2025 at 1:20 pm #16879578
Hey there,
It looks the source plugin/theme separates the strings. I searched for "weeks" and found the string. Check image attached. Please do the same, search for specific words of the string, you should find them.
April 2, 2025 at 12:06 pm #16886882
freelancerI
Hi Lucas,
yes I solved this problem thanks,
But I want to ask another question for translate Listing Single V1.
I am reproduce steps below:
1. Navigate to listimet page: hidden link
2. Click on one of the listimet for exmaple which are added from submit a listing recently just for a test.
3. Go at the listing page: hidden link
4. Observe that after menu does' t display any switch toggle language to translate into English this Listing Single V1.
To translate this Listing Single V1 I tried to reigister widget at WPLML-> settings->Custom XML Configuration but it don't works as excepted.
You have reproduce the issue in the test/staging site hidden link
thanks.
April 2, 2025 at 7:33 pm #16888765
Hey there,
The Listing element was set as untranslatable. To fix it, please follow these steps:
1. Go to WPML > Settings and mark Listing as Translatable, under Post Types translation;
2. Go to the listings tab and add the translation to the listings;
Please note that for other elements contained in the Listing element, they should also be set as translatable. Once they are translatable you can translate them either in WPML > Translation Management, or in Taxonomy translation, depending on their type.
Also note that the custom XML only works for custom page builder widgets, it's best not to touch it, as it can lead to problems. Let me know how it goes.
April 3, 2025 at 9:24 am #16890921
freelancerI
Hey Lucas,
Thanks for your answer,
It works what you mentioned but I have some parts of the elements that are not translate when user selected English language.
I made a video please check and if you have any might ask me.
April 3, 2025 at 1:38 pm #16892672
freelancerI
Hi
might I have any feedback?
April 3, 2025 at 4:12 pm #16893942
I apologize, our queue has been higher than usual lately. Thank you for waiting.
The fields that have numeric values, must be set as "Copy" in WPML > Settings. Please do as follows:
1. Go to WPML > Settings > Custom Fields Translations;
2. Click on "Show System Fields";
3. Search for all the missing fields and set them to "Copy". Save;
4. Update the original template and save. Update its translation;
5. Update the original listing and save. Update its translation;
I've tested with a couple fields in the staging version and it worked. Let me know.
April 4, 2025 at 10:32 am #16896795
freelancerI
Hey Lucas,
I followed steps above it works well!
about title for single listing. How we can solve?
in listing page English lanauage: hidden link
as you can see title heading are in English.
I tried to change costume _listing_tagline, and _listing_title as Translate as you can see in the screenshot but for title don't works.
Please for more detail find link of the vide below:
New threads created by Lucas Vidal de Andrade and linked to this one are listed below:
https://wpml.org/forums/topic/split-template-items/
April 4, 2025 at 4:30 pm #16898513
freelancerI
Might I have any feedback?
April 4, 2025 at 5:08 pm #16898552
Hey there,
I've created a new ticket for this issue, since it's unrelated to your initial question. I'll answer you there in a couple of minutes:
