You are experiencing issues with WPML not recognizing content built or modified in Divi. Changes made to the original language pages in Divi, such as adding a breadcrumbs module, are not reflected in the translations, resulting in a broken layout on the translated pages.
We discovered that there were custom CSS applied to your page that were not compatible with WPML. We recommend removing these custom CSS and retranslating the page to fix the issue. This should help in correctly reflecting the changes made in the original language across the translated versions.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your current situation, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please do not hesitate to open a new support ticket at WPML support forum.
This topic contains 19 replies, has 0 voices.
Last updated by Lucas Vidal de Andrade 2 months, 3 weeks ago.
December 2, 2025 at 10:37 am #17625676
WPML Supporter since 11/2023
Hey there,
Thank you for waiting. We found that there were custom CSS applied to the page, which weren't compatible with WPML. Removing them, and retranslating the page, fixed the issue. Check the image attached.
Let me know if it works as well for you.
December 4, 2025 at 7:19 pm #17636037
Sabra
Thanks for the update, I just saw it now because I do not receive any mails when you reply and the answer was on the second page. I hadn't seen it. I will check and get back to you. I am busy with a big project and will probably only manage to answer on Monday the 7th. Thanks for your great support and patience!
Sabra
December 10, 2025 at 10:18 am #17651324
Sabra
Hi, and first of all, sorry for the delay in getting back to you with feedback. Thanks so much for your wonderful support and help with this complicated website. In any case, this issue was resolved by removing the custom styling in the divi module...
I might have to come back to you and ask more questions as I go through the entire site carefully and try to get it back up to speed. I will have to find a way to style the breadcrumbs properly as on the detail pages they look like this when a title is long instead of everything being compact and on one line (see screenshot)... However, this is a minor difficulty at the moment. I appreciate the time and effort you took to help me.
Best, Sabra
December 13, 2025 at 5:18 pm #17661568
Sabra
Hi Lucas and thanks so much for your great support last week. I'm sorry to bother you again. I was able to move forward a bit with the work on the website but now have run into a new issue:
I have a post type: "chapters" and have used the divi builder to create a template for this type of post. In English I have some headers: Source, Language and Download and some dynamic content that is being pulled in. Both the headers and the dynamic content are somehow not being "seen" by wpml. Can you help me again? I am attaching some screenshots of the problem.
In the first screenshot you can see that the template for all chapters has been built with the Divi builder. The content is added to the regular WordPress backend and I am importing some dynamic content generated by the pods plugin such as the Source, the Language and the Download file. In the second screenshot you will see that I used String Translation to translate the three headers and in the third you can see the front end and where the dynamic content should appear (to the left)
For example, on this Original language post: hidden link
You can see to the left the Titles and dynamic content. However when you click on DE or FR the titles do not change and the first link does not go to the the german or french version but remains the same as the english. Can you help me again?
New threads created by Lucas Vidal de Andrade and linked to this one are listed below:
https://wpml.org/forums/topic/split-divi-template-not-fully-translated/
December 15, 2025 at 10:38 am #17663567
Hello there,
I'm glad I was able to help. I'm going on vacation soon, and since we can only handle one issue per ticket, I've created a new ticket for this new issue you brought:
It will be handled by another supporter. You'll soon receive an answer there. Thank you for your patience.
