The client is using the Divi Builder to create a template for a custom post type called "chapters". Although they have translated the headers (Source, Language, Download) using String Translation, the dynamic content pulled by the Pods plugin and the headers are not being translated or displayed correctly in other languages.
1. We set the Lang field to be translated and instructed the client to update the chapter in the default language. This allows the Lang field to be visible and translatable when updating translations.
2. For translating links, we advised using the search field to find and translate them alongside the chapters.
3. To address untranslated labels on the front end, we recommended translating the body templates. The client should visit the templates page and ensure all templates are translated.
If this solution does not resolve your issue, or if it seems outdated, please check the related known issues and confirm that you have installed the latest versions of themes and plugins. If the problem persists, we highly recommend opening a new support ticket at WPML support forum.
Last updated by Sabra 4 months ago.
Assisted by: Osama Mersal.
December 15, 2025 at 10:09 am #17663412
Sabra
Hi Lucas and thanks so much for your great support last week. I'm sorry to bother you again. I was able to move forward a bit with the work on the website but now have run into a new issue:
I have a post type: "chapters" and have used the divi builder to create a template for this type of post. In English I have some headers: Source, Language and Download and some dynamic content that is being pulled in. Both the headers and the dynamic content are somehow not being "seen" by wpml. Can you help me again? I am attaching some screenshots of the problem.
In the first screenshot you can see that the template for all chapters has been built with the Divi builder. The content is added to the regular WordPress backend and I am importing some dynamic content generated by the pods plugin such as the Source, the Language and the Download file. In the second screenshot you will see that I used String Translation to translate the three headers and in the third you can see the front end and where the dynamic content should appear (to the left)
For example, on this Original language post: hidden link
You can see to the left the Titles and dynamic content. However when you click on DE or FR the titles do not change and the first link does not go to the the german or french version but remains the same as the english. Can you help me again?
December 17, 2025 at 11:14 am #17670615
Osama Mersal
I'm Osama from the WPML forums support team. I'll be glad to help you today.
First, apologies for the delayed response; it was due to a higher workload.
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
❌ Please back up your database and website ❌
✙ I need your permission to deactivate and reactivate the plugins and themes, and change site configurations. This is also why the backup is critical.
Osama
December 18, 2025 at 12:43 pm #17674737
Osama Mersal
Thanks for the access details. I set the Lang field to be translated. After that, I updated the chapter in the default language.
When updating the translation, you can see the Lang field and translate it. For the links, use the search field to find and translate them alongside the chapters. (Kindly check the attached screenshot)
After that, you will be able to see the correct data on the side panel on the front end.
Osama
December 19, 2025 at 6:28 pm #17678888
Sabra
Hi, That is great. Now I could change the language "English" to "English" for the German and "Anglais" for the French. However, I was unable to change the Titles: Source, Language and Download. These are part of the Divi Template built with the Divi Builder and affect all Posts with the category "Chapters and Excerpts"...
December 21, 2025 at 9:53 am #17680438
Osama Mersal
Thanks for the update, and apologies for the delayed reply due to the weekend.
The body templates are not translated, so you need to translate them to translate the labels on the front end.
Please go to this hidden link">page and translate the templates.
Osama
December 22, 2025 at 9:07 am #17681491
Sabra
Hi Osama and thank you so much for your help with my translation issues. I am now trying to copy over the changes you made to the sandbox website to the actual live website so that I can translate properly. You explained above that you set the Lang field to be translated. Where do I need to do this? After I manage it, I will then also try to translate the body templates and make the live site work properly. Thanks again for your help and support.
December 22, 2025 at 9:10 am #17681495
Osama Mersal
Please go to WPML -> Settings -> Custom Fields Translation, set the fields to Translate, and save.
After that, you would need to update the post in the default language and update its translation.
Osama
December 22, 2025 at 9:24 am #17681621
Sabra
Hi Osama and sorry for bothering you again... I managed to find where to translate the "Lang"... I'm now trying to figure out the rest and will contact you again if I have any questions. Thanks so much for your excellent and timely support.
December 22, 2025 at 9:42 am #17681682
Sabra
Hi Osama, Sorry but now I am running into a new issue. I have managed to translate the titles on the page by translating the page builder templates but now the links on the left are showing up as html instead of as links. Can you help me understand what is happening? Here is the issue you can view on the live site. The original language page is correct: hidden link While the translations show html on the left:
German: hidden link
French: hidden link
Thanks for your patience with me!
December 22, 2025 at 9:46 am #17681687
Osama Mersal
Please edit the translated body template using Divi and check these dynamic fields.
If that didn't help, please share the live site access details so I can check the issue.
Osama
December 27, 2025 at 11:15 am #17689421
Sabra
Thanks, Osama, for your great help. For now things seem to be working. I'll reach out to wpml again if I run into any other problems.
