Last updated by Mohamed Sayed 1 year, 12 months ago.
Assisted by: Mohamed Sayed.
July 30, 2023 at 8:46 am #14122203
tomaszK-37
It also does not want to fire elementor for additional languages, each language is a separate domain.
July 30, 2023 at 8:54 am #14122215
Mohamed Sayed
Please try the following steps:
- Go to WPML > Languages > Language URL format
- Make sure the "Validate" option is enabled for the secondary domains.
- Enable the "Auto sign-in and sign-out users from all domains" option
- Save it
- Now go to Permalinks and save the permalinks once.
- Logout from the primary domain
- Now login from both domains, you can log in from secondary domains using /wp-login.php at the end of the second domain. And example login path will be:
To make sure you are correctly logged in from both domains you can check if the WP top admin bar is available from both languages.
- Once you are logged in from both domains, check if you can edit the page in Elementor from the secondary languages.
Let me know please if that helps.
Kind regards.
