The client was inquiring about how WPML handles having both Google and Deepl translation engines enabled at the same time.
We explained that WPML prioritizes the translation engines based on the order of preference set by the client. The engine listed at the top will be used first, provided it supports the language pair required for the translation. If the top choice is not compatible, WPML will then attempt to use the second option, and so on. We recommended reviewing our documentation on how to change automatic translation engines for more detailed information:
https://wpml.org/documentation/automatic-translation/how-to-change-automatic-translation-engines/
If this solution does not apply to your situation, or if it seems outdated, we encourage you to open a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum: https://wpml.org/forums/forum/english-support/.
This topic is split from https://wpml.org/forums/forum/english-support/
Assisted by: Mihai Apetrei.
