The client is unable to see translations for certain fields, which appear to be Custom Post Types.
We recommend checking if these Custom Post Types are set to "Translatable" in the WPML settings. Here's how you can do it:
1. Navigate to WPML > Settings.
2. Scroll down to the "Post Types Translation" section.
3. Locate the correct Custom Post Types.
4. Set them to "Translatable".
5. Return to the previous screen, and you should now see the + icon for adding translations.
For more detailed instructions, please refer to our documentation:
Translating Custom Posts
If this solution does not apply to your case because it might be outdated or not relevant to your specific situation, we encourage you to open a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please contact us in the WPML support forum.
Last updated by Mihai Apetrei 1 year, 4 months ago.
Assisted by: Mihai Apetrei.
April 13, 2024 at 6:17 pm #15515086
Артур Струнгар
There is no translation in these fields. How to do it?
April 13, 2024 at 6:21 pm #15515089
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
From what I can see in the screenshot, it seems that those are Custom Post Types that first need to be set as "Translatable" - probably they are currently set as "Not Translate".
Please go to WPML > Settings > "Post Types Translation" section > find the right Custom Post Types > set them to "Translatable" > and now go back and you should be able to see the + icon for translation.
Related documentation:
https://wpml.org/documentation/getting-started-guide/translating-custom-posts/
I hope that you will find this information helpful.
Mihai Apetrei
